Car running like bad after remap
Zans Jul 12, 2019 at 11:21 AM
  1. Zans
    Zans Member
    39
    Hello, i own and audi s8 APY and after getting it remaped multiple problems popped up:
    -car runs very rough on cold start (wiggles between 850 to 1200) for about 10 mins (driving or idle) and then runs normally at 850ish rpm. On a hot start, 90deg, it runs direcly fine at 850ish rmp
    -after hard acceleration it pops and bangs from the exhaust, then smells like unburnt fuel, i mean i like the sound of it but it makes the engine run too rich i think and that's not good
    -spark plugs were also changed at the tuner for brand new NGK BKR7E, but the clearance wasn't measured cause the tuner said it doesn't matter (what?)
    -timing is sh*t and it shows itself during driving, when driving in 4th at 100kmph, the car starts shacking back and forth, same goes for any gear when continuously driving in low gear at high rpm (more than 3500) (also attached the timing log in neutral gear)
    -one error code popped up: 17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    -Now i'm just thinking that the tune was very bad and the best idea now would be to get the ecu back to stock
    -At some point got a low oil pressure but that was only once and when driving up on a high slope
    -The tuner also told be to replace my coils with tfsi ones because the car is misfiring (was running great before the tune)
    -Car has 190000km on the clock, it made 283 hp on the dyno
    My mods: Airtech FMIC, BKR7E spark plugs, n75j, 76mm catless downpipe, n112 moved under the intake manifold (basically the vacuum hose to the recic valve is longer, doubt it makes any difference), SAI delete, ramair air filter, silicone hoses ect...
    Thanks a lot for reading)
  2. Avatar
    Google AdSense Advertisement
  3. AndrewW
    AndrewW Member
    39
    19
    Zans likes this.
  4. <tuffty/>
    23,607
    5,152
    Can people please stop asking for map files on the open forum... this is not a file share site and while I sympathise with your issue ASN cannot be associated with sharing map files as legally its a very grey area..
    I will edit your post accordingly....
    With regards to your issue....
    The fault code you have is related to the cam belt being a tooth or more out... this tends to lead to running issues... I suggest you investigate top to bottom timing and fix that issue first
    Other running issues could be from air leaks... I would suggest a smoke test along with a visual inspection to check if there are any obvious split hoses (normally PCV related)
    As for fitting TFSi coil packs... firstly your packs are bolt down so you will need adaptors regardless as the APY cam cover isn't designed for push in coil packs... secondly don't get dragged into the hype of TFSi coils... they are realistically no better than fitting a new set of 1.8t ones... buy genuine though..
    Did you get an AFR plot from the dyno?
  5. AndrewW
    AndrewW Member
    39
    19
    Oops my bad!
  6. Zans
    Zans Member
    39
    Thanks for the reply!
    Sorry for asking about the files didn't know it was illegal.
    I will check the timing belt, and do a smoke test, what is AFR plot?
  7. AmanDosangh
    AmanDosangh Member
    70
    12
    I had that same error code when my timing slipped 2 teeth. May be worth a check.
  8. superkarl
    superkarl MAN OF STEEL
    9,975
    2,653
    Your description of your running issues are very similar to when my timing was out. I urge you to take Tufftys advise on that as a priority
    AmanDosangh likes this.
  9. Zans
    Zans Member
    39
    Thanks a lot! Will investigate as soon as possible
  10. badger5
    10,117
    2,315
    as said start with fixing the mechanical issue. correlation error, belt slipped or on wrong from last change.
  11. Zans
    Zans Member
    39
    Okay thanks a lot! What should be tge correct clearance for the spark plugs? Or it doesnt matter?
  12. Avatar
  13. <tuffty/>
    23,607
    5,152
    Fuelling... APY is a narrow band ECU for the lambda... it won't log air fuel ratio (AFR) under full load like wide open throttle on the road or a dyno so most tuners use a wideband AFR logger to be able to tune fuel properly
    You 'should' have this with your dyno plot assuming they logged it using the dyno
  14. Zans
    Zans Member
    39
    He only gave me a paper with the power and torque curves. Will ask him about the AFR
