Cannot rotate engine, hard lock / clunk at 80% rotation on crank.
grrr - bin? I have the CHRA fitted and it rotates okay, but is it not long for this world?
I reckon this is caused by running 18-19psi boost without a 3inch downpipe, where the gas is entering the chamber must be so hot.
20181018 195730
Moving on this weekend and next week - hopefully anyway...
Getting a new hotside, so build the mutant-turbo (you see what I have done there ;) ) and fit with the pipework.. <-- this will be interesting as I bought an entire cheap Chinese turbo just for the hotside so will sell on the actuator, compressor housing and CHRA afterwards to try and get back a couple of quid.
  • Getting Elring head gasket kit and bolts delivered <-- need to see if half moon is included - they are only a few quid with GSF60 or HALLOWEEN80 codes
  • New exhaust valves - cheap but expensive if you know what I mean..
  • New ARP Cam Pulley Bolt
The above will let me reconstruct the head
New Top Timing Cover <-- they are surprisingly difficult to fit in a TT compared to an S3 - hence why it is broken.
I need to get an after-run water pump and I think I will buy a coolant flange as mine was leaking from the temperature sender unit, and they are famous for leaking, and I bet the o ring is the same price as the full flange.
A question I do have is regarding the running in process if I have replaced rings and big end bearings? do I need to run in with cheap oil for a short period then cheap oil for a medium distance then good oil? including filter changes at the same time?
looking for advice for quality studs and locking nuts for do I get nord-lock washers? I think I got some locking nuts when I worked on the S3
K04 to downpipe - 10mm aren't they
K04 to manifold through a Chinafold - they are quite long
Head to exhaust manifold - (the studs are good so I just need 8mm nuts)
Turbo to manifold
M10 x 70mm long with stainless nordlock washers is what I’ve gone for .
I have extras , pm me your address and I’ll send you some
Cool thanks for the size I assume these are standard pitch?
Thanks for the nordlock offer, I will see what ones I still have, i bought loads but didn't pay the quid each they are for sale online. Did you buy special studs and nuts, I have read several threads over the years of these undoing.
okay so how on earth someone can manufacture and deliver a turbo for £100 is just crazy - this was from "maxspeeding" redused from £166 , I have removed the hotside to go onto my old compressor housing, hybrid CHRA, 15psi actuator.
And now will need to port the wastegate penny as you can see in the photo's is this why they have a reputation for compressor surge?
got all my other parts delivered today too busy week ahead :)
20181027 110404
20181027 110407
20181027 110425
20181027 110531
Lol... and check out the turbo to manifold alignment.
It looks like the cnc template was made with the gasket on upside down and only located with two holes. The supplied gasket doesn't fit a stock K04 either, so I need to widen the hotside to meet the oem gasket.
Buyer's be aware...
Screenshot 20181027 150059 Gallery
Screenshot 20181027 150032 Gallery
So this is the porting for the fake k04 hotside and the start for the Chinafold to match the gasket and the stock manifold.
Screenshot 20181027 163103 Gallery
Screenshot 20181027 163047 Gallery
Wow! lots of carbide bits and patience Stuart... I don’t envy you, but great to see you getting on with things
Light lap on the inlet valves completed, just about to start on the new stelite exhaust valves.
Screenshot 20181027 205630 Gallery
Reactions: hydro s3
going to need some carbide action on that wastegate port.. dayum! its small!
gotta luv chinese products.. copies of copies of copies of .............. yowza
like I said if I flip over the gasket the top and right holes are aligned and so is the port and the wave is exactly aligned, so someone measured something incorrectly / upside down, when creating the program. Amazing some people would just fit it and it'll only have 70% open, plus a tiny wastegate. the OEM K04 is exactly 9.4 mm from bolt to port and this is 8.4, 8.6, 11.4. My old hotside would have probably been okay with the hair line fracture just not worth the risk.
That's about stock from the looks of it, it actually opens up quite easily it's like a thin top layer, wasn't finished properly hence the errors shape.
Spending this evening getting the exhaust valves in, fingers crossed I won't lose any half collets done 4 of 8 so far :)
Can anyone explain these instructions / warning regarding the camshaft seals?
Screenshot 20181028 194010 Gallery
Screenshot 20181028 194018 Gallery
Screenshot 20181028 194025 Gallery
Reactions: superkarl
so this is what a winter evening project is all about a nice couple of hours fitting something whilst watching crazy ex-girlfriend, sabrina Spellman and x-factor :) I would not be relaxed if I had lost some bits - it's the more difficult ones tomorrow night ;)
20181028 203028
20181028 203105
Reactions: ADs3 and hydro s3
View attachment 168706 View attachment 168707 View attachment 168708
Don’t try and push the plastic guide through the seal.
Clean the cam, put the guide on the cam, and slide the seal over the guide onto the cam. Don’t run the engine for 4hrs.
That’s how I read it
Can they be fitted on the camshaft before fitting on the head or do they need to be pressed on after fitting the cams?
I expect they were ruined already lol, there's probably a chemical which goes off when the centre is popped out.
Thanks Karl... it makes it much easier doing that.
In other news I have ported the hot side now too match the gasket. It is done using aluminium oxide grinders, 6 for like about £3 I have ordered some carbide bits for the chinafold, I reckon that is made from stronger stuff.
Screenshot 20181029 173649 Gallery
Reactions: hydro s3, ADs3 and S3AMJ
Nice work.
Don’t be afraid to go a bit deeper.
You can knife edge the wastegate port in there also
Reactions: ADs3
yay got the inlet valves in last night - I reckon it took a couple of hours with a couple of breaks for my aging back i'm sure it would be quicker on a proper bench and with spare collets in-case you drop one and some are a lot easy to do as some of those gaps are tiny. The easiest way is to put a bit of grease on the inside of the collet too then they sort of find the correct place on the grooves and you can push it around to the other side of the valve to put on the other half.
I should be able to get the cam pulleys sorted this evening. but I must do some gardening today - it's finally the garden fire season.
20181029 213903
20181029 213914
20181029 213855
20181029 214018
20181029 214233
20181029 214333
20181029 215013
20181029 220731
20181029 221234
Reactions: hydro s3, Rainbird and <tuffty/>
Question over torque for ARP cam pulley bolt? The Haynes manualstates 65NM /48lb_ft but I'm sure I have seen 55 lb_ft for the arp bolt which is more like 75nm?
Any thoughts or anywhere around there is fine?
those collets!!!! urgh!!! hahahaha
Hope you've had fun there!
This part is definitely one of the more rewarding parts and gives you that light bulb moment in how it all works
Reactions: Stuart B
It's actually quite therapeutic and what you envisage as a winter project.
Had a great fire last night and freaked myself out this is the fire and me photoing myself, at the same time...
Screenshot 20181031 194014 Gallery
Tonight is back to normal, kids coming over complaining about their relationships bahhhhh. Leave-me-alone
Fitted turbo yesterday need to torque down the oil and water lines and connect up the other ends onto the block and sump along with the sports cat, and try to replace one of the back box exhaust mounts which has given way, I did get a replacement one but has the bolt holes in the wrong places, so I might get by just replacing the hanger.
20181030 153806
am waiting for my neighbour to help with the cam pulley bolt, but can maybe make a start of the teeth rattling chinafold port tomorrow afternoon.
20181030 173157
Reactions: hydro s3
I'm sure someone recently said their EGT sensor was loose in the hot side, well as tuffty pointed out fake k04s doubt have a good EGT fit. This is 3 crush washers. Lol... maybe I have no idea what the EGT accuracy is now either....
Screenshot 20181101 230409 Gallery
Spent about 40 minutes on a couple of the exhaust ports on ChinaFold today.
And instead of going round my neighbours after work for the cam pully, took the grand children to recycle the pumpkins in the woods. They weren't happy leaving them for the animals and doggers / passers by but meh...
Screenshot 20181101 230841 Gallery
Reasonable couple of hours this morning,
Fitted cat to downpipe and exhaust.
Screenshot 20181102 122036 Gallery
Screenshot 20181102 122022 Gallery
Fitted new afterrun pump
Screenshot 20181102 122045 Gallery
Fitted new flange and temperature sensor o-ring it used to leak.
Screenshot 20181102 122011 Gallery
Will continue with the chinafold this afternoon.
Reactions: hydro s3 and Rainbird
Looking for torque setting of the inlet cam bolt.
Is it the 'cam position wheel' at 18lb?
Screenshot 20181103 153552 Gallery
Head together... blimey... that's long.
10nm for caps (seems low but hey), 55lbft ARP Cam Pulley Bolt with red loctite (That is damn tight)
New half moon gasket and hopefully the cams are in the right place.
Roll on tomorrow... Maybe put it on if I'm done with the chinafold?
Screenshot 20181103 203156 Gallery
Screenshot 20181103 203214 Gallery
Screenshot 20181103 203146 Gallery
Reactions: hydro s3
Not worrying about that for the moment I'm already at about April before the current plans are finished.
Blimey, fitted the ported chinafold ( remember to fit it after the bracket ;) )
I used the existing fat washers, but bought some copper / self-fastening 13mm m8 nuts. But you need to grind a lot off the top of the manifold to get it to locate past the bits of alloy sticking out the head. That I did maybe 10 times until it sat flat.
Screenshot 20181104 203134 Gallery
Screenshot 20181104 204447 Gallery
Porting wise all I did was open up the runner entries to the gasket and ground the collector down, the cylinder 4 collector had a bit of the runner tube sticking into the collector area which I reduced slightly
Non welding solution for additional exhaust hangers ?
So... I know it's a TT and not an A3/S3 but I need an additional bolt on exhaust hanger and bracket or maybe only a downpipe hanger.
Essentially when I fitted the downpipe to my s3 i fitted it from above and removed the hanger, this was fine because the s3 exhaust hanger was at the front of the centre box and therefore held the exhaust tight. The TT has a hanger at the rear of the centre box - this is too much of a gap. I'm sure I saw someone bolt an extra bracket in the tunnel. The downpipe might be a little more difficult as it is on a curve and across the prop shaft.
Okay thanks that's pretty much what I need unless mine will also vibrate on it.
Pictures of the collector porting?
The collector is the most important part of porting... the manifold as cast caused misfires at higher RPM's so the porting that Bill does is imperative to preventing that from happening
If you haven't ported the collector enough then you may get misfires
<tuffty/>
