- Joined
- Sep 14, 2008
- Messages
- 24,836
- Reaction score
- 6,078
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
Main gasket hole - the diameter of the large bore from mani into turbo. Might just be the photos but it doesn't look like you've opened it up much, compared to the image S3AMJ posted.
IIRC Bill opens these up to 48mm/similar.
Yeah but isn't s3amj going gasketless, the hole in the turbo (apart from having to re-port the Chinese rubbish alignment) and the manifold are both the same as the gasket if i open it up the gasket won't work.
ours is indeed gasketless, and its bigger to increase flow, reduce back pressure, which still is a good thing on any k04, hybrid or not.Im not sure how Bill runs the hybrids weather they are gasketless or not bud. As long as your openings match... that’s your aim. Bills one might be bigger because it’s a hybrid turbo as apposed to your standard k04. Someone else in the know could confirm this.... I think your biggest mission is to clear the guts out of the collector to prevent the misfiring that PT was explaining.
why using studs not bolts. you will regret this
thats what we use yes. A2/A4 stainless M10 x 70 bolts with nordlock washersGrrr... thanks Bill, I assumed 70mm studs + nordlock washers and copper flashed self locking nuts, was the route. I can see a 70mm bolt would fit okay and also you cannot remove the manifold with the studs in place as the compressor housing gets in the way (so studs are bound to seize etc) I will get some more.. is A2 / 304 stainless good enough.
Thanks as always.
indeed yes. no oil to damp movement so its all springs vs cam lobesokay, so I cannot turn back the inlet cam the bolt just undoes? I will check the torque and add some Loctite.
but this is a video of the cams turning over (at least no valves broke this time ) is the cam chain adjuster supposed to lift and drop so much? or is it because there is no oil in the engine and it is not connected?
http://freesomes.co.uk/ttstuff/turningover.mp4
it is what elring say it is..arrgghh
well this is annoying.
haynes states 40 NM + 90 degree + 90 degree
but what is this on my elring document?
I really dont think I will manage the second 90 degree turn - is it really 40NM then 60NM then 90 degree + 90 degree (to reach the 60NM that was a quarter turn from 40NM)
thoughts before I commit to another 90 degree turn? that will be really tight, might need a breaker bar!
they feel terrible on that second 90 dont they...feel the stretchso that was easy enough with a 3 foot bar, just shaking at the end we'll see in a few days I suppose
well completed a couple of things today I might do some more after the F1 race -maybe check the timing and pull the grenade pin or fit the intake.
got a little lost with the 70mm bolts I needed to cut them down to about 62mm which makes sense really as the 70mm studs were poking out. it maybe the Chinese hot side is not as deep?
I also added the sealant to the corners and put on the new cam cover gasket - I think that is supposed to be left to dry.
my biggest challenge is I think the MOT is running out soon and I need to reinsure in December so I need it running and then run-in so that I can get it MOT'd as they needed to rev the nuts off my S3 to get the sports CAT hot enough.
View attachment 170609 View attachment 170610
