  2. Dismiss Notice
Cannot open bonnet - help!!
DMCC May 12, 2020
  1. DMCC
    DMCC Registered User
    On my 2009 a3 I had to remove the entire front panel to replace the radiator,
    To make sure it aligned ok when done I closed the bonnet, now I cannot get it open! It is closed firmly on the latch
    The front bumper is still removed from the car (luckily) , I have tried someone pulling the interior latch whilst I push down on the bonnet but no joy. I can hear the cable being worked
    It doesnt appear to be like my old mk5 golf that had torx screws so I could access it to remove the entire mechanism
    Any help appreciated!
  2. Avatar
    snack-media
    Advertisement
  3. DMCC
    Anyone??
  4. ahtcap
    ahtcap Registered User
    341
    55
  5. ch1z64
    ch1z64 C'mon you's bhoy's in Green Silver Supporter VCDS Map User
    4,204
    930
    now reading your post you removed the whole bumper etc to replace the rad pack pack . Which i gatther is not the same , only my thinking is if it was the correct 1 then you woukdn't have said problem
  6. DMCC
    That guide must be for an older one because the bolts that hold the bonnet mechanism within the slam panel are on the engine side. Nothing there at the front.
    For future, if any one comes across this on a later 8P model it seems like you will have to climb under the car and reach up to unscrew the 3 Torx bolts holding the mechanism to the slam panel.
    Once unscrewed you can then left the bonnet and the mechanism up together then detach the cable with a screwdriver....
    henkkeumus likes this.
Tags:
