  2. Dismiss Notice
Can you turn off egr via vcds?
HOGG Sep 19, 2019
  1. HOGG
    HOGG Registered User
    851
    284
    As title really...
    Is it possible to turn off the egr via vcds. As I've deleted it out of the engine bay...
    Sent from my SM-G930F using Tapatalk
  2. Avatar
    snack-media
    Advertisement
  3. Darren92
    Darren92 Registered User
    2,469
    649
    Not on this era of vehicle.
  4. Gazwould
    Gazwould Registered User
    7,736
    3,127
    Not delete but adaption which really turns it down.
  5. HOGG
    851
    284
    I've physically removed it[​IMG]
  6. Gazwould
    7,736
    3,127
    Eml on yet ?
  7. HOGG
    851
    284
    Yep. Hence the question LOL
  8. jay1601
    jay1601 Registered User
    1,416
    117
    Either have it mapped out or bit of black tape on the back of the dial card light gone
  9. tr7
    tr7 Registered User
    414
    124
    43
    Hi Gaz, how is this done? Any links? Cleaned it out before and never again!
  10. Gazwould
    7,736
    3,127
    What Audi do you have ?
  11. Bluepower
    Bluepower Registered User
    269
    79
    Needs to be mapped out, only way to get rid of the MIL, and readiness check during MOT...
  12. Avatar
    snack-media
    Advertisement
  13. tr7
    tr7 Registered User
    414
    124
    43
    It would be for a 2.0 BRD
  14. Gazwould
    7,736
    3,127
    Either remap out or egr adaption which minimises it's operation in VCDS .
  15. tr7
    tr7 Registered User
    414
    124
    43
    That's what I meant, how is it done in VCDS, any guides?
    I'm a fairly new/light user so am not using 10% of what it is!
  16. Gazwould
    7,736
    3,127
  17. HOGG
    851
    284
    I might try and vcds it low
    tr7 likes this.
  18. tr7
    tr7 Registered User
    414
    124
    43
    Who has done this for 2.0 (BRD) TDI?
    I'm struggling to find the correct values to enter. (No suggestion bubble/popup in VCDS for this one)
    Any ideas or where to source them?
  19. tr7
    tr7 Registered User
    414
    124
    43
    Anyone?
  20. Pie-eyedpiper
    Pie-eyedpiper Registered User
    806
    332
    No idea, I had my light deleted when I had mine remapped.
    Have you taken the cooler off too?
  21. tr7
    tr7 Registered User
    414
    124
    43
    I haven't taken off anything on this car.
    As per the other posts and youtube video, you can apparently essentially minimise its function all together with the correct value in VCDS.
    Basically as close to a delete as possible without physically modifying the car
    (If I understood it correctly)
  22. Pie-eyedpiper
    806
    332
    Just remove it all, and smooth out the airflow. Plus no possible cooler pipe leaks and easy turbo access.
    The engine bay looks much less cluttered with all the extra frippery gone too.
  23. tr7
    tr7 Registered User
    414
    124
    43
    Oh Trust me. I want it all removed.
    Not only have I myself cleaned out the inlet manifold and egr on my Special Edition. Disgusting and hours of dirty work.
    I’ve had in the past the pleasure of having to pay Audi to replace the EGR in my old S-Line at £1k plus.
    So I’m all up for deletes. Both DPF and EGR. But can’t justify the spend at the moment.
    and I’m not giving it a go on my driveway.
  24. RandomZephyr
    RandomZephyr Registered User
    Have you removed your DPF? I've read you're bound to cake up your DPF rather quickly without an EGR.
  25. Pie-eyedpiper
    806
    332
    I think it's true, if you have a DPF it relies on the EGR for re-gen etc. I'm not sure if the DPF can be deleted with no other issues.
    That only applies to the BRD though, I've got a BRE and no DPF thankfully.
  26. Pie-eyedpiper
    806
    332
    £1k plus, wowser. Definitely a reason to delete.
    If you're able to, I'd definitely give it a go. The delete kit isn't expensive and whilst the cooler removal can be a bit tricky it really isn't a difficult job. I've got a great link to to write up if you need it.
  27. tr7
    tr7 Registered User
    414
    124
    43
    Yeh I was in Europe at the time and had no other real choice (or trust) than to take it to the main dealer. Didn't even have tools to try.
    So was €1150 EUR or so in the end by Audi. But that's simply because Audi don't clean parts. Knowing what I know now, probably could have cleaned it out.
    But it was an actual physical blockage. The car didn't have the power to drive out of my underground parking garage the next morning. It wasn't limp mode. Had to get it towed to the dealer after driving 200 mile home on the EML.
    And since then when purchasing my current B7 I stripped down and cleaned out the Inlet manifold and EGR myself, which I started on a whim and turned out to be a complete pain in the ****. And ended up being an allnighter as I wasn't going to 'half' do it. So persevered and have 'fond' memories of that too.
    So you could definitely say I'm not a big fan of EGR systems to say the least and know personally all too well the pain in the **** that they are. And that's before any performance or simply engineer in me despises the concept of them all together.
    Pie-eyedpiper likes this.
