One thing I find annoying is when using the temp settings I have to adjust both, on my A8 I could press a button and adjusting the heating on both sides from the drivers side button, is there any way this can be done on the c6 PFL climatronic? Thanks.
Yes you can.. Press and hold the drivers side temperature knob and it'll sync both sides.. Sent from my SM-N960F using Tapatalk
You can also go into the A/C settings on the MMI and select the option to synchronise both sides. This will remain until you turn it off
That’s brilliant thanks guys, I think because I currently have MMI 2G low+ I don’t have the option on MMI to synchronise the temp, it’s been a while but I think that’s how it was done on my A8. I’ll try the button press trick and I’ll see if it can be coded with VCDS for it to be on the MMI.
Just to add, I did the pressing the knob trick and it worked a charm, this also keeps the sync I guess until it’s turned off, so adjusting the drivers button reflects on the passenger one too for the duration of the trip, it also comes up with a little sync logo on the MMI when adjusting just so you know. thanks again guys been doing my head in for a while.
Mine stays in all the time.. Not just the duration of the trip.. I've bought mine in June and synced it right away and all I need to do is adjust drivers side. Passenger side will show same temp set on drivers side! Sent from my SM-N960F using Tapatalk
Iirc you only have 1 fan on the c6 it’s not like the D3 I had before. I'm unsure about air distribution as I usually just leave it an auto.
