Can OBDeleven fill my coding needs?
bobbytomorow Jul 3, 2018
  1. bobbytomorow
    bobbytomorow New Member
    21
    I have recently retrofitted a multifunction steering wheel to my 2006 A3 following a tutorial on a vwvortex, now I just need to do the coding so the buttons on the new wheel function properly. Although the tutorial uses VCDS to do the coding could this also be done using OBDeleven?
    This is where I’m at in the tutorial for reference:
    Basically would I be able to do that step using an obdeleven ?
  2. Avatar
    Google AdSense Advertisement
  3. dp_motley
    dp_motley 2012 A3 1.6 TDI S line 2019 A3 35TFSI S line Team Nano Grey Sportback TFSI Owners Group S tronic S-line owners group
    997
    277
    Yes, it would be able. I coded puddle & warning lights recently with the OBDeleven by changing numbers. Everything went well. I bet coding the steering wheel wouldn't be an issue.
    Suffolk Bloke likes this.
  4. bobbytomorow
    21
    Thanks for that’s answer! I couldn’t find confirmation anywhere that obd11 would be able. To code a MFSW retrofit but if it can do what you have done via coding I don’t see why not.
    Time to take the plunge and find out. I will report back with results soon as one ships to me :^)
  5. ch1z64
    ch1z64 C'mon you's bhoy's in Green Team Imola TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    3,590
    766
    It might be worth sending theses guys a PM @NHN or @Ash187 and they should be able to help as this is what they do for a living @NHN is mobile
    bobbytomorow likes this.
  6. bobbytomorow
    21
    Ok the OBDeleven arrived today and it did what I wanted, I was able to enable the paddle shifters as well as the audio controls.
    dp_motley likes this.
  7. dp_motley
    997
    277
    Congratulations, well done!
  8. Michael Paul shields
    Michael Paul shields Member Sportback TFSI Owners Group Team Phantom Audi S3 Manual
    39
    hi what software can i download to for the laptop to get obd11 working i have the usb and bluetooth version
  9. bobbytomorow
    21
    I’m not sure what you can use with a PC, as far as I know it only works with their proprietary Android app which is what I use. I bought an android device specifically for the purpose of using obd11 because they don’t have an iOS app.
  10. Michael Paul shields
    39
    hi bobbytomorow what android app have you downloaded for it to work
  11. bobbytomorow
    21
