can hear a whining.
Darren1983
Hi All,
Ive got a whine coming from somewhere, I don't think its anything to do with gearbox, i can hear it when i drive, it changes pitch with acceleration. also if i dip the clutch and rev the engine it makes the same noise and changes pitch.
any ideas?
Darren1983
just checked my power steering fluid and its at minimum.
could this be causing the noise?
carlcall
Well-Known Member
It could be if it was sucking air into the system but IIRC you would feel it through the steering wheel. It could be a worn bearing on any of the ancillaries.....without hearing it, it's quite hard to diagnose.
But on a side note I have whining noise that comes and goes as the Mrs gets in and out of the car.....whisper quiet when it's just me :tearsofjoy::tearsofjoy::tearsofjoy:
Darren1983
the steering feels fine mate, it definitely changes pitch when accelerating when in gear or when clutch is pushed down and you ref the engine.
hahahaha yea that's another whine that i hear all the time when the other half gets in and out of the car.
Darren1983
Yea true mate.
Had another listen and don't think it's the power steering pump. It seems to come from the back of the engine. Thats maybe because it's closer to the bulk head so that's where I'm hearing it.
Darren1983
still trying to figure out what this is, it doesn't seem as bad when the car is warmed up but on first start up it sounds like a loud super charger or something.
Darren1983
Can anyone tell me how to upload a video from my Samsung. I've got a video of the noise.
Darren
Darren1983
Had a quick check this morning ingredients but still can't seem to find a leak.
I may have to get under the car and check for anything.
Darren1983
Just a thought but it couldn't be anything to do with me removing the airbox baffle could it
Dani_B19
Audi-sports own special child.
That's got nothing to do with the airbox mod, sounds nothing like mine.
What engine you got mate? Have you had someone listen under the bonnet while you Rev it? Any loss of power while driving?
Darren1983
It's the tfsi engine mate.
Yea I got my brother to rev it. It sounded like it was coming from around the turbo area but could be wrong
Dani_B19
Could be a boost leak or possible a failing DV.
So do you have any fault codes coming up? How's the car driving compared to the noise being there?
Darren1983
The car is erratic at the best of times mate. Sometimes it picks up.well and sometimes it feels like I'm driving with the hand brake on.
It's got the revised dv on it but I suppose that can't rule out a possible leak
Dani_B19
Any fault codes? When was the DV fitted? D or G?
Have you had a leak test done? Mine ran like a bad of **** and my DV was split literally in half and the PCV valve was leaking like a siv, changed both and it's like a completely different Animal.
Darren1983
ive not managed to get it plugged in anywhere to check.
I replaced the pcv and dv at the back end of last year when I got the car bud.
aragorn
"Stick a V8 in it!"
Staff member
Moderator
That noise is 100% the turbocharger. Doesnt sound well.
Its not a leak, your not producing any meaningful boost revving the engine like that for it to leak.
Darren1983
thanks for that mate. its been doing my head in. its always louder first thing in a morning too.
Il have to save up and get it reconditioned.
Darren1983
priced up getting the turbo refurbished, its going to be £200 which doesn't seem bad however I have no suprus money at the moment so I will have to do some saving.
Dani_B19
There you go mate, Aragon knows his stuff.
Darren1983
Thanks everyone just need to nurse it until I have the money now as it's my daily driver
Darren1983
Evening.
Hopefully I'll be removing the turbo this weekend.
I've looked at a thread on how to do it and looks fairly straight forward. The only thing I'm unsure of is removing the cat from the turbo, it looks as the the nuts underneath are hard to get too. Will I need any particular tools to get to them?
Also is there anything else I need to be aware of?
Darren
Darren1983
I've just started dismantling this and the exhaust bolts where not tight at all. One of them could of been undone just by using my fingers? Is this normal
Darren1983
Eventually got the turbo off. The blades are rubbing against the turbo housing
