  2. Dismiss Notice
Q5 Can anyone help with VCDS Adaption settings???
Arkious Aug 14, 2019
  1. Arkious
    Arkious Active Member Team Daytona Audi RS3 Audi Q5 5 Cylinder
    520
    165
    43
    Hello everyone!
    I have recently retrofitted the facelift led tail lights to my Q5 8R, but the adaption settings are proving somewhat difficult!
    I’m hoping one of you kind folk with a facelift 8R with LED tail lights and living in the UK could take note of their adaption settings please?
    It’s Module 46 - Adaption, but you will need to enter Password 16017 to view them. I need channel 195 to 210 if at all possible please!
    Thanks very much :)
  2. Avatar
    snack-media
    Advertisement
  3. -Ju-
    -Ju- Well-Known Member Team Floret Silver SQ5 owners group VCDS Map User
    3,324
    1,204
    I'll grab my 2015 SQ5 settings later pal
    45bvtc likes this.
  4. Arkious
    520
    165
    43
    I’d really appreciate that mate thanks very much :)
    45bvtc likes this.
  5. -Ju-
    3,324
    1,204
    Here you go pal
    195,12,N/A,N/A,N/A,N/A,
    196,44,N/A,N/A,N/A,N/A,
    197,5,N/A,N/A,N/A,N/A,
    198,37,N/A,N/A,N/A,N/A,
    199,16388,N/A,N/A,N/A,N/A,
    200,16420,N/A,N/A,N/A,N/A,
    201,12,N/A,N/A,N/A,N/A,
    202,44,N/A,N/A,N/A,N/A,
    203,9,N/A,N/A,N/A,N/A,
    204,41,N/A,N/A,N/A,N/A,
    205,13,N/A,N/A,N/A,N/A,
    206,45,N/A,N/A,N/A,N/A,
    207,51202,N/A,N/A,N/A,N/A,
    208,51234,N/A,N/A,N/A,N/A,
    209,0,N/A,N/A,N/A,N/A,
    210,0,N/A,N/A,N/A,N/A,
    Arkious and 45bvtc like this.
  6. Arkious
    520
    165
    43
    Thanks very much pal, really appreciate you going out your way for it :)
    I won’t get to try them till the weekend now due to shifts but at least I have them ready :)
  7. -Ju-
    3,324
    1,204
    No worries pal, let me know if it helps!
    Sent from my SM-N960F using Tapatalk
  8. Arkious
    520
    165
    43
    Hello, sorry for the delayed response as I only got round to trying them this morning due to various bits and bobs! But yes this coding worked perfectly but it wasn't as straight forward as coding only. Thanks for the coding though, I really appreciate it :)
    So, here is my findings which is hopefully useful to someone in the future. As above, in order to view these settings in Module 46, the password 16017 must be used.
    Coding
    Green is coding that remained the same and Red is coding that needed changing.
    Once the coding has been changed, the negative terminal MUST be removed for 10 minutes or it simply does not work. This is something that has had me going round in circles for a fair bit time!
    Pre-Facelift with LED Rear Lights
    195 - 6148
    196 - 6180
    197 - 5
    198 - 37
    199 - 16388
    200 - 16420
    201 - 12
    202 - 10280
    203 - 0
    204 - 0
    205 - 0
    206 - 0
    207 - 0
    208 - 0
    209 - 0
    210 - 0
    195 - 12
    196 - 44
    197 - 5
    198 - 37
    199 - 16388
    200 - 16420
    201 - 12
    202 - 44
    203 - 9
    204 - 41
    205 - 13
    206 - 45
    207 - 51202
    208 - 51234
    209 - 0
    210 - 0
    Wiring
    I purchased 1 ROW spec light and 1 US spec light and then changed the indicator LEDs from Red to Amber, so I found the wiring differences for both lights which is shown below. The wiring is shown from the tail light to the body
    ROW Spec Tail Light
    Orange (Pin 1 - Pin 3)
    Red (Pin 2 - Pin 2) *
    Yellow (Pin 3 - Pin 1) *
    Black (Pin 4 - Pin 4)
    US Spec Tail Light
    Red (Pin 2 - Pin 1) *
    Yellow (Pin 3 - Pin 2) *
    The difference between the two is that the brake light flashes with the indicator in the US where as the ROW spec they work independently.
    -Ju- likes this.
