Can anyone help me with this code?
rb1763
[/URL][/IMG] eml keeps coming on after I've cleared it, runs rough when cold.
Any help would be much appreciated.
Ruhel
Never seen a fuel needle go down so fast!
Where are you based.
Can you post some details on the vehicle.
Welcome to the forum.
Ruhel
What are you using to clear the code? Does it let you know any error codes?
Ruhel
Vcds lite I get p3228, I can't find any information on this
In German. Used google translate so may be some issues.
Error code : 19684 P3228
This error code is "Manufacturer Specific" (for each car maker a different definition and meaning). The following description / symptoms / causes / solutions specific to VAG cars.
nl Exhaust Bank 1 Sensor 1, single cylinder control signal sensor unlikely lean
du Abgas Bank 1 Sensor 1 Einzelzylinderregelung Lambda Sensor Signal unplausibel lean
and Exhaust Bank 1 Sensor 1 Individual cylinder control implausibly lean
Additional information on the error codes.
Note : The following information is not coming from the VAG group, or from numerous other sources. Complete and error can not be guaranteed. Keep critical thinking.
Possible symptoms:
Possible causes:
  • Wiring and / or connections faulty
  • Lambda sensor defective
  • There is something wrong with the fuel mixture (fuel trim)
Possible solutions:
  • Check / repair wiring and connections
  • Check (measuring blocks) / replace sensor
  • Read the information and control capabilities of the fuel trim
Extra information:
  • Negereer this mistake, especially if there is a DPF is present
