CALLING ALL 1.8tfsi/S3 OWNERS
Would you all be so kind as to see if your car makes this noise , it’s Lind a “tring” noise and cones from the “ cam adjuster solenoid valve. I am trying to build a case against Audi as they are saying it’s a “Characteristic” if the engine , when I know it’s not . It happens every time, just when starting to pull away it goes “Tring” then dip the clutch (or slow down in auto) and it goes “Tring” again . It only happens when taking up drive ( under load) , if you sit out of gear and blip the throttle it does not do it . Just put your window down and you will hear it or not ( probably not though) .
Could you please put in the comment :
Model
Year
And if it does it or not
Many thanks again Folks
Gordon
josul
S3 8V FL 2016 - does not make this sound.
There is an option to create a survey when creating a post on here. I know there might be a lot of options but depending on the number of responses it could be worthwhile setting up. It might help the number of responses too.
Any thanks for the info , I will have a look at setting up a survey but can only put about 12 words in the question so I can’t put my description and video link in .
Just needing to get as many responses as I can do I have evidence that it’s not a “ characteristic” of the engine , many thanks again , Gordon
Hi Josul, do you personally know anyone else in here that has an S3 or 1.8tfsi that you could ask to check and respond , I just need as many as possible so I can go back to Audi . A Huge thanks again , Gordon
GSB
Well-Known Member
Gold Supporter
That engine sounds a little rattly all round, but can confirm my 2016 FL S3 definitely didn’t make that noise.
JohnM100
Gold Supporter
Gordon,
I appreciate the frustration getting this diagnosed but you have several threads on this. You can always ask a mod to change the thread title to make it more relevant, rather than start a new one.
I could not see from either of your threads what year and mileage your car is (though the 1.8 was only available in UK for a couple of years).
To answer your question:
PFL 2013 1.8 TFSI - didn’t have this noise when I had it as I would certainly have noticed.
FL 2018 S3 - doesn’t have this noise.
Has the dealership ruled out a timing chain issue?
Good luck with you quest.
Ok Folks , small update for you, I was in at Audi Today and the Tech let his “boss” hear it and has agreed that there should not be a noise like that , it is booked in for Monday 2nd March and I am getting a courtesy car .
Will keep you all updated on progress , many thanks again to you all ,
People knowledge is POWER on here
