Hello all,
It’s been a while since I posted anything, so if anyone’s interested I thought I’d post an update.
Recap\Update
The original aim was 300HP.
The current mods to TT Quattro 2002 BAM;
- Complete 3" exhaust
- Decat
- F23 turbo
- Chinafold Ported & polished as best I could (the stainless manifold cracked up like a dried lake bed)
- Bosch 550cc injectors
- Uprated fuel pump
- Mushroom air filter
- Bager5 TIP
- New NGK plugs & coils
- Refurbished brakes with Mtec discs & pads
- The head has been refurbished, new water pump timing belt etc, compression is good on all cylinders (180).
- Combined boost, oil temp, oil pressure & voltage gauge
- Poly engine & dog bone mounts
- Coil overs
- In garage to be fitted EBay FMIC
After doing some remapping the MAF reading is between 245 and 252 (the recent rise ambient temp seems to be killing a few horses), any mapping tweaks I make now makes little to no difference.
Clarification
How accurate is divide the MAF by 0.8 to give the HP as when my car was dyno’d HP worked out to be the MAF divided by 0.84?
Has anybody got a dyno graph of MAF v 300HP for a BAM\1.8T engine?
How much difference does ambient temp have on these 1.8T engines with regard to HP?
Advice Required
When I had the stainless manifold there was a huge boost spike at 3K RPM which I never really tamed, using the Chinafold the boost spike has gone but it’s a little flat until 4K at which point it picks up. Any ideas if this flat area can be improved by mapping or is it just that’s the way the Chinafolds are? I’ve tried various mapping tweaks AFR, Load, timing greater\lower, even tried fiddling with the waste gate PID with no noticeable effect.
Also I have the EBay FMIC to install anybody know what if anything to expect after install?
Recap\Update
- Decat
- F23 turbo
- Uprated fuel pump
- Bager5 TIP
- Coil overs
Clarification
Advice Required
