Brembo 18Z Calipers (Yes it's a new set of questions)
LostEnigma Oct 9, 2018
  1. LostEnigma
    LostEnigma New Member
    15
    Hey guys.. Me asking what I think is a new question about these calipers when used on the 8L platform.
    I got a set for an absolute steal, selling my ibiza cupra calipers, disks and pads left me with change after buying these...
    OK.
    1) Do you have to use the Golf 4 R32 334mm disks when fitting these to our cars, or can you use the bigger Cayenne, Touareg and Q7 disks (can't remember off hand what size they are)
    2) If you use the bigger disk, is it possible to slot the PCD like what was done here by S3 Paul on his rear disks upgrade: https://www.audi-sport.net/xf/threads/s4-rear-300mm-conversion-kit-completed.172858/
    3) Does anyone have the blueprints/scematics for the brackets to fit on either disk as with being in South Africa, everything is stupidly expensive to get here and paying what will equate to 300 GBP is a bit stupid for brackets... So I would like to get them made locally.
    4) Do our brake lines still screw into these or is it 100% required to get lines made?
  2. Avatar
    Google AdSense Advertisement
  3. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,824
    765
    Use r32 disc I have a set to fit aswell but apparently pedal travel isn’t good the Leon Cupar r brakes are seen as a better upgrade the brackets are around £100 on eBay over here You can also get the brake lines aswell on ebay
  4. LostEnigma
    15
    Hey man, I am not after the performance side of things at all.. I just really want this for looks (stance barbie)
    Do you know of any reason why you cant use the Touareg's 350mm disk etc?
    Custom's hits South Africa really bad.. that is the problem
  5. LostEnigma
    15
    Calipers aquired
    334mm disks aquired
    Pads aquired
    Anyone willing to send dimensions etc of the brackets?
  6. craigt1985
    craigt1985 Active Member
    225
    Acquired*, sorry three times in a row got to me :tearsofjoy:
    Tj 0785 likes this.
  7. LostEnigma
    15
    That was terrible on my part... Haha wow :') forgive me
