Brake upgrades
Andyb5tdi Jun 1, 2017
  1. Andyb5tdi
    Andyb5tdi B5 1.9TDi AFN saloon TDi Audi A4 quattro S-line owners group
    312
    86
    I've fitted new front callipers, discs (standard 288mm Brembo) and pads but the brakes still don't feel that sharp. My old 306 Dturbo had GTi 6 front brakes (283mm) but the callipers were a lot bigger (still single piston) and it was violently quick at stopping. (I appreciate the 306 is 300Kg lighter, but the brakes on the A4 feel like they don't have much clamping force if that makes sense.
    Are there any calliper upgrades that keep the 288mm discs?
    I've also seen 312mm discs mentioned, using the OEM callipers (288mm) but not sure this would improve things as heat build up isn't my issue.
    What are the 312mm discs from and do they use bigger callipers?
    What size wheels are needed to fit the 312mm under?
    Many thanks
    Andy
  2. Avatar
    Google AdSense Advertisement
  3. aragorn
    18,728
    897
    Have you properly bedded in the new pads?
    The 312 upgrade does make a difference, as your applying the same clamping force at a greater distance and thus producing more torque.
    But realistically a new healthy 288 setup should stop you pretty well. I run 288's on my track car and its fine.
    I'm not really sure what the physical size of the caliper matters.
    Andyb5tdi likes this.
  4. Andyb5tdi
    312
    86
    Hi Kev, yep pads are bedded in, but only cheap pads tbf as I did before I thought about keeping it. What pads are you running?
    As yes, the bigger discs make sense now. What are they from and what size wheels are needed to fit them?
    Andy
  5. aragorn
    18,728
    897
    the disks are from a B6 3.0L. You need TT caliper carriers (or S3 or some others), and you use the normal A4 pads.
    I've currently got EBC yellowstuff in the car but they're useless. I typically just buy decent pads like Ferodo, Jurid, Brembo etc.
    They fit under the standard "sport" 16" wheels, by a whisker.
  6. Andyb5tdi
    312
    86
    Thank you Kev, I'm keeping an eye out for some 17" OEM wheels so they should fit fine :) I will probably get some decent pads and when the discs need replacing get some 312mm :)
    Browett1982 likes this.
  7. Rfmacaskill
    Rfmacaskill Member
    125
    Hi Andy, I 'just' did the 312 conversion myself last weekend. I've got 17" boleros and there's loads of room to spare. I bought TT carriers from eBay for about £50 inc postage and standard A8 disks from eurocarparts for £54. I used my existing callipers and brembo pads.
    Part No's for the disks and carriers are as follows:
    D2 A8 312mm x 25mm rotors 8E0 615 301 R
    TT Carriers 1J0 615 125 A
    The whole thing took me just over an hour which inc removing the sliding pins and giving everything a good clean and re-grease.
    IMO the difference is profound for not a lot of money. Now to fit new HEL Stainless hoses and replace the fluid which should improve the pedal feel and remove the initial squidgy feel...all in time for next weeks road trip to Le Man!
  8. aragorn
    18,728
    897
    as i said in another thread, those arent A8 rotors.
    No A8 in the UK or Europe uses that disk. Its used on larger engined B6 models and some A6's. The part number is valid however, its just not anything to do with an A8.
  9. Rfmacaskill
    Rfmacaskill Member
    125
    Ah...OK...bad info from another forum then!! They work regardless.
  10. aragorn
    18,728
    897
    Yeh lots of the yank forums seem to suggest its an A8 part, maybe they got different stuff over there. Not here though!
  11. Andyb5tdi
    312
    86
    Thanks guys, do you think they would fit under 16" wheels?
    Looking forward to doing the conversion when the time comes. Unless I could use the. Current 288's to upgrade the other halfs 6n polo lol.
    Off topic, have you been to Let Man's before? I've been a couple of times but not for a few years. The first time I went BMW won :) It's a fabulous atmosphere.
    Samuel c5 Q likes this.
  12. Avatar
  13. aragorn
    18,728
    897
    yes the 312's fit fine under the 16" sport wheels.
    Bear in mind the 312's you retain the original calipers, and only swap out the carrier.
  14. Andyb5tdi
    312
    86
    Awesome, regarding wheels I'm after slightly wider tyres rather than bigger wheels, although the 18" do look smart lol
  15. Andyb5tdi
    312
    86
    @Rfmacaskill can you remember what model TT you got the calliper brackets from or do they all use the same brackets?
  16. Andy avant b5
    Andy avant b5 Active Member
    955
    139
    43
    I believe mk1 but not sure did mine only 4 months ago they are a big improvement IMG_20170906_195643400_zpsillhvwmb_edit_1510497086608.jpg IMG_20180211_105915057_HDR_zpspnzcabpi_edit_1518349150700.jpg IMG_20180211_111808994_HDR_zpsqokuuilk_edit_1518349231608.jpg
    dubcool.pc likes this.
  17. Andyb5tdi
    312
    86
    Thanks Andy, they look awesome :) What make discs are they?
  18. Andy avant b5
    955
    139
    43
    Cheers mate they are mtec
  19. Andy avant b5
    955
    139
    43
    Just need to do my rear discs now they are rubbish
  20. Andyb5tdi
    312
    86
    Good plan :) I've got a long list of to do's but find no fun playing cars in the rain and snow lol
  21. Andy avant b5
    955
    139
    43
    I am the same bloody British weather on my list next are my coilovers which I have had for 5 months now but the weathers stopping me from doing it then the bigger turbo hopefully gets better soon
  22. Andyb5tdi
    312
    86
    @Andy avant b5 nice one :) Is yours a 1.8t? What coilovers have you gone for?
    I need to do the osf wheel bearing, but while I'm there I figure I may as well do:
    Top 4 link arms
    Bottom 2 link arms
    Shocks
    Springs
    Track rod ends
    NSF wheel bearing
    And fit the OEM 17" B6 wheels I've had for ages.
    In for a penny, in for a pound lol .
    Oh and the 312mm conversion if I can find some brackets :)
  23. Andy avant b5
    955
    139
    43
    Yes mate mines the 1.8t currently looking at hybrid turbos my coilovers are kw there's loads of brackets on eBay at the moment
  24. Andyb5tdi
    312
    86
    Nice one :) What power are you going for? I was going to rebuild my Bex in the B6, but then someone mentioned that a 2.7tt would fit so I ended up buying a C5 Allroad lol. I liked the KW (V2 iirc) on my E30. It certainly handled well :)
  25. Andy avant b5
    955
    139
    43
    I've got the Saab red injectors front mount intercooler and a bex manifold not fitted any of them yet waiting on the turbo was hoping for a bex turbo but are very hard to find hoping for around 250bhp
  26. Andy avant b5
    955
    139
    43
    Just found a bex turbo in really good condition 70 pounds bargain
  27. Andyb5tdi
    312
    86
    Nice :) Is a Bex turbo a KO3 or KO3s?
  28. Andy avant b5
    955
    139
    43
    It's a ko3s going to get it returned to be on the safe side it only cost me 60 quid
  29. Andyb5tdi
    312
    86
    Get it returned dude? Bargain :)
  30. Andy avant b5
    955
    139
    43
    Sorry refurbed
  31. Andyb5tdi
    312
    86
    Wow, bargain dude
  32. Andy avant b5
    955
    139
    43
    There shaft play so am going to send it away to be refrubed but for 60 pounds bargain and they are very hard to get hold of spent 3 months trying to find one
  33. Avatar
  34. Andyb5tdi
    312
    86
    Nice work Andy :)
  35. Andy avant b5
    955
    139
    43
    Cheers mate how's your a4 going
  36. Andyb5tdi
    312
    86
    Not touched them to be honest mate, the Berlingo alternator has died, so have ordered a cam belt kit to do at the same time, and will pull it apart tomorrow to get the alternator repaired on Monday and then can hopefully crack on with the B5. The blower motor sounded like it was dying on Monday so I ordered one up and it's arrived, just awaiting fitting and I ordered some decent speakers for the rear shelf as the OEM ones were well past their prime. Now just to find my V12 amp and then I can pull the interior apart and cable it. Tempeted to put my sub in the boot, but maybe I'm a bit old for that kind of action lol. The B6 still awaits removing the half an engine left in it and the all road awaits finishing Stripping it down to find the water leak, but I'm none to keen in this recent weather despite how much I love driving it. Hopefully it will soon be mobile again :)
  37. Andy avant b5
    955
    139
    43
    Wow loads to do then mate
  38. Andyb5tdi
    312
    86
    Yep, no rest for the wicked as they say, oh and need to build the man shed this year as well to house the car bits lol.
  39. Andy avant b5
    955
    139
    43
    Lol love it
  40. Andyb5tdi
    312
    86
    Does anyone know what TT's use the bracket we need? Was it some of the 225bhp cars/ all of the 225bhp cars/ the 3.2s?
  41. Andy avant b5
    955
    139
    43
    I am pretty sure it wasn't just tt that had 312mm I am sure leon cupra 180bhp also ran them
  42. Andyb5tdi
    312
    86
    Well hopefully I have tracked down a set of brackets from a TT (time will tell!) And I've just cross referenced the disc part number and it seems it's fitted to quite a few cars:
    So it looks like I have a set on the Allroad and a set on the B6 to choose from for test fitting :) Happy days :)
