Brake pad warning?!
c4pete
I am not aware of them doing anything to the discs. I guess the question is how worried are you about the brakes. They didn’t say the discs were gone and the pads are new so its not a worry. I image there is a warning for discs as well so if that happens then its time to change.
What I am most interested to know is if these will squeak...
Hi, just thought I'd chip in and mention I have a FL RS3 and the brakes have never squeaked/squealed, but it was an Audi staff car, so I'm pretty sure they've done something to it to stop this - they'd also painted the hubs, so no rust there either. I thought I'd read somewhere that the squeaking can be stopped by replacing the pad backing shims with a new design?
T
Tristan2
Guest
Mine squeaked on and off the first week of new ownership
A few hard bursts of the brake pedal fixed this,now no squeak since the first week of March
Dan_DJT
I had my local garage change the pads today £210 with labour. I left the discs. They told me that the discs are showing wear but the local garage reckons they could be done on the next pad change which would probably be around this time next year.
23k mileage currently - I am not keen on spending anything extra that doesn’t need doing!
Which pads did you go for ?
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
Staying tuned, very interested to hear the difference.
Does anybody know what pads Audi use as standard though? Because my belief was it is a Brembo brake setup so surely has Brembo pads already?
I had it set in mind that I was going to go for Ferodo, but will see how you get on with these regards to squeal and see how they compare overall taking into consideration the saving between Brembo and Ferodo.
Brembo may have their label on the backplate and the box but for sure they don't manufacture the pads and/or the friction material, and there lies the problem. The 8P RS3, for example, were/are Pagid. Can explain more on the 27th, M... :blink:
Like 2011 8P RS3 47i6 upgrade pads here, M: Brembo and Audi logo but stamped PAGID on the backplate and friction material.
Too silly for words, the 47i6 upgrade just didn't resolve the brake squeal issue, and neither did the 8V 8-pot calipers... :sadlike:
Spinstorm
I don’t know what pads they ordered. I just decided to let them order whatever it was. Clearly they went for the least expensive pads. I think the Brembo on that link on eBay about were around £89 so I imagine something like that... but I could be wrong.
Honestly I am just happy to have saved over £350 having them do it instead of Audi. My car is going into Audi on the 16th to have the sun roof frame replaced (hopefully) and all the other little niggles taken care of so they can charge Audi warranty their stupid expensive prices as long as I am not paying!
Having looked at the discs since the change they look perfect - no issues. I don’t know if the low pads caused them to look like they may need a change but looking at them now they are definitely not something I will be changing. The last thing on the list right now is the front tyres that I believe are still legal but I imagine I will have to change them in the next month or so. The online price above in one of the posts was £130 for each tyre which I can live with.
Let’s put this into perspective I got my pad changed and will be able to buy two new tyres online for £100 less than Audi would have charged JUST for the pads.
Just started getting squeal on mine; had it a few months now (the car not squeak!).
It’s a late 2015 8V. Not planning on putting cheap pads (I.e red stuff) on - had yellow stuff on a previous car and wasn’t impressed - but I don’t want this behaviour either as I daily the car and the noise is unpleasant.
I’d be happy with Brembo Sport or Performance Friction.
What do people generally go for to retain performance but get rid of the racket?
Neil_79
Front pads are easier than most as you dont have to remove/slide the caliper out of the way.
I picked up some Brembo HP2000 front pads today, will do a review of them when I have fitted them. A few pics below.
Sent from my ONEPLUS A5010 using Tapatalk
Any update on how you’re finding these as I’m thinking about upgrading my OE pads to these.
c4pete
Just spotteed a set on ebay (search for item number 302548242490) ... I think they are the correct pads at the bargain price of £66.99 delivered!!! CarParts4Less is the same company as EuroCarParts :)
Dan_DJT
Yeah good price for a standard compound set of pads
juice
Those Brembo pads will be perfect for normal use
How did your hp2000 pads work put?
im
Going to euros today to buy brembo xtra pads and discs for the rear (310mm cross drilled)
I was going to buy the 356mm vagbremtechnic but heard a members bracket snapped and caused issues.
appreciate your response in advance.
Dan_DJT
im
HP2000 pads were OK, maybe a little bit noisy but performed well.
wuta3
FWIW I got some Ferodo pads DS5023/DS4967 and they were WAY WAY quieter than OEM and have not squeaked at all
