  2. Dismiss Notice
  1. niedzial1983
    niedzial1983 Registered User
    337
    136
    43
    Can anyone recommend pads to go with standard rotors that dont generate brake dust or very minimum . I just had my wheels refurb and its a nightmare at the moment
    Sent from my SM-G920F using Tapatalk
  2. Avatar
    snack-media
    Advertisement
  3. 1210tech
    1210tech Four Ring Fanatic
    698
    Haven't used them myself yet but a friend has recommended EBC Redstuff pads for minimum brake dust
  4. Redbaron1973
    Redbaron1973 V10's rule
    97
    14
    I changed from OE to brembo pads. Much less dust.
    1210tech. - had rubbish Experience with EBC in the past. Personally I wouldn't use them again if they were free.
  5. RAF_S7
    RAF_S7 Well-Known Member Gold Supporter
    1,953
    1,069
    I'm running EBC Redstuff pads with zero issues.
    My S7 was suffering from excessive brake dust, which in turn caused low speed brake squeal. Both now resolved (lm about 2500 miles on the EBCs now)
    I believe there was a redesign of the Redstuff pads, and they now have a higher ceramic content.
    I highly recommend. :racer:
    ruairi83 likes this.
  6. ruairi83
    ruairi83 Registered User
    1,825
    612
    I upgraded the front calipers, front discs and pads on my 2015 a4 to the genuine S4 ones. New genuine disc and pads where got to match currently have 4K miles on them. I'm getting excessive brake dust on drivers side and squeal at low speeds too... I ordered another set of genuine pads. Might sell these genuine ones and get the EBC ones.
  7. RAF_S7
    1,953
    1,069
    EBC Redstuff's are the way to go. The ceramic content prevents excessive brake dust and squeal. I'm running them on my OEM discs and I'm not seeing any significant additional wear on the discs.
  8. ruairi83
    1,825
    612
    Sounds good mate. Thanks
  9. Redbaron1973
    97
    14
    Glad to hear they have redesigned the product and its working for you.
  10. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User
    7,311
    3,651
    I have Redstuff front and rear and compared to OE pads they are very much better. The brake dust is a lighter color , comes off easily and there is not so much of it. As stated above the EBC formulation for Redstuff and indeed several other pad types has changed over the years
    BigjoeC likes this.
