2011 car
I used vcds to open calipers due to rear discs and pads change, i removed caliper and noticed the caliper on nearside wasn't fully open, so i tried again with vcds, Nothing happened comes up with error when i try open calipers, any idea?
I closed calipers again, hoping to try open again with vcds, but this time got error messages on vcds, not allowing them to open now, ive removed the motor too, but still no joy, even though left rear caliper is off the car, i did connect the caliper motor to see if it would open the caliper on the other side, but nothing.???
Ive ordered a new caliper as the seal was split by time I'd finished with it, caliper won't be here till Tuesday.
New caliper will be fully back so once i fit it, im hoping vcds will open other side, if not im not sure what do???
Reply Quote
1 - 1 of 1 Posts
Write your reply...
Recommended Reading
Reply Quote
1 - 1 of 1 Posts
Write your reply...
Recommended Reading
- Broken mmi button
Technical & Faults - Manual gerabox problem (TDI 177hp)
Technical & Faults- 0
- 143
- G
gtest · updated Apr 4, 2016
- 0
- Hub bolt torque
Chassis, Wheels & Tyres- 2
- 823
- P
PeteUK · updated Feb 20, 2019
- 2
- Turning hubs when car is jacked up?
Main Message Centre - 2017 AUDI Q3 STEERING WHEEL AIRBAG REMOVAL
Modifications
- VerticalScope Inc., 111 Peter Street, Suite 901, Toronto, Ontario, M5V 2H1, Canada
