  2. Dismiss Notice
Brake Caliper Assembly Grease
Alex C Jan 4, 2012
  1. Alex C
    Alex C Well-Known Member VCDS Map User
    3,423
    412
  2. Avatar
    snack-media
    Advertisement
  3. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,381
    5,614
    Only reason to use it I can see is to ease sliding the pistons in... its not like you have to re-silicon them every 5k miles etc..
    Personally I have only ever used brake fluid to wipe around piston seals before assembly in the past... not sure I would want any other lubricant potentially mixing with brake fluid in the cylinders and contaminating it...
  4. Alex C
    3,423
    412
  5. Jacko4130
    Jacko4130 Goodie Gum Drops
    842
    When i am rebuilding calipers at work we use a silicone lube. I belive its made by a company called "Hunters" and its not that expensive to buy.
  6. Alex C
    3,423
    412
    is it only appiled to the o-ring seal? I searched for "hunters silicone lubricant sealant " couldnt really see much
  7. TDIb0y
    TDIb0y Registered User
    While we're on the subject, would you use this kind of thing on caliper slider pins too, or copper grease / red-rubber grease instead?
  8. a3tdi2001
    a3tdi2001 Registered User
    437
    Silicone grease for any part that comes into contact with rubber or plastic. A light smear around exposed part of brake piston before pushing in, rear brake sliders, hydraulic struts on boot/bonnet, a smear on your door seals to stop the doors freezing shut etc...
    Carlube now do a version for sensible money: Carlube Motor Oil - Carlube Silcone Grease
    RS also do it for sensible money if you live near one: Buy Precison Lubricants RS Silicone Grease, 100g Tube RS ##MPN## online from RS for next day delivery.
