  2. Dismiss Notice
Brads A4 2.0 TQS build thread
Bradderz_1988 Jul 29, 2011
  1. Bradderz_1988
    4,029
    286
    Definately also brings a bit of character to the car and also keeps the red/black theme going.
    Started on the rear diff carrier today and also the cam cover need go get more laquer as ive ran out lol
  2. Avatar
    snack-media
    Advertisement
  3. EvilSnow
    EvilSnow Registered User
    596
    33
    I can't wait to see this on road man
    Sent from my SM-G920F using Tapatalk
  4. Bradderz_1988
    4,029
    286
    Me neither:tonguewink:
  5. Bradderz_1988
    4,029
    286
    All ready for laquer in the morning
  6. Bradderz_1988
    4,029
    286
    Got the rear diff crossmember finished and apikol bushes cleaned up, greased and refitted and got the cam cover finished off today took the paint off the earth ground and also were the coils bolt down pretty happy with how everythings turned out.
  7. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,187
    401
    Could swear that my cover doesn't have those cylinder numbers on.
  8. Bradderz_1988
    4,029
    286
    Its an old style aeb one ive also shaved some not needed bits that hang off to tidy it up a little.
    Heres a normal one compared against mine
    slepy likes this.
  9. Bradderz_1988
    4,029
    286
    Got the bushes removed from the subframes just need to remove the clips for the brake lines off the rear subframe but need to take a pic so i now which ones go where and what orientation there in. Also got the crash bar removed from the bumper started to trim the number plate area up but need more cutting discs lol and trimmed some bits that were visible through the side grills.
    Bushes cam out fairly easy once the top lipped part of the bushes were removed just a quick hit with a hammer and they were out.
    And the bumper removed from crash bar and tidied up the number plate area and centre grill bar ends ready to fill them in.
  10. Bradderz_1988
    4,029
    286
    Got the crash bar modded this morning. Thinking of adding some reinforcement to the centre bar as its a little flexible.
  11. Bradderz_1988
    4,029
    286
    Wont be seeing that behind the bumper ......
  12. Avatar
    snack-media
    Advertisement
  13. Bradderz_1988
    4,029
    286
    Found my rear turrets to be a bit corroded on the rear face its not structural as its only 1mm thick and only spot welded to the turret itself.
    Set about removing the pieces with a air chisel which quickly removed them leaving just the spot welds and bottom weld, so i then ground down the spot welds and cleaned up the bottom weld ready for some 2mm thick sheet metal after they have been shotblasted then going to look at getting them galvanised as aragorn suggested weld them up and then powdercoated.
    Heres how they turned out
    Also got the rear top arm outer bush replaced and one inner on the other side got to get one of the bushes out the rear upright as that needs replacing from when i fitted it and had the socket the wrong way round so it pressed the metal in to the socket was fine but needs doing (OCD) lol
  14. Bradderz_1988
    4,029
    286
    Happy new year guys
    Progress is still real slow but now xmas etc is out the way i need to crack on and ive decided on keeping the S4 B6 brakes and boleros as i didnt really want to ditch them for aftermarket wheels, the boleros are off to get shot blasted next week along with subframes and rear turrets all for £30 off a mates work colleague. Then im going to go for oem looking boleros and get the diamond lip recut but maybe a tad darker on the spokes, i hate diamond cut rims due to the fact they tend to corroded very easily so im going to try see how they go.
    I was originally going to just refurb them myself as i started to strip them back with nitromors but i got them back to pretty much original and they have grown on me and you dont see many off our cars sporting oem looking boleros these days.
    Few pics
    Maybe a tad lighter than these
    Or should i go with oem silver ?? Opinions ??
  15. slepy
    2,187
    401
    Personally don't like dark wheels on black car. Shiny silver / fully polished ftw
  16. PaulJC84
    PaulJC84 Owner
    2,939
    25
    A darker silver should be good. I borrowed a set of full silver ones a few years ago and I quite liked how the car looked with them on.
    I could not be bothered with the diamond cut lips around here though as they will go milky pretty quickly without loads of looking after.
  17. aragorn
    18,716
    906
    Do NOT go down the polished/diamond cut route.Its a complete waste of time, the companies that do it know that and wont even warranty their work.
    Personally i dislike silver wheels, and favour darker shades. Never black though. The wheels on the BMW were done in Bronze which looks great against the black. For some reason i have NO photos of it on those wheels though :(
  18. EvilSnow
    596
    33
    Have you got the part numbers for these mate?
  19. Broken Byzan
    Broken Byzan Photographic Moderator Staff Member Moderator VCDS Map User
    13,232
    470
    I found on over 300hp it slipped quite easily. TTV and rs4 kit would be my choice, well was after spending £200+ on the v8/SMFW
  20. EvilSnow
    596
    33
    TTV?
  21. aragorn
    18,716
    906
    TTV Racing. They sell a 1.8T flywheel thats machined to take a standard RS4 clutch.
  22. Oranoco
    Oranoco Registered User
    4,026
    417
    Got one in mine, great service and so far seems to work well.
    Only downside is a heavy pedal which my other half hates which is a sod as it may mean we take the TT to the Nurburgring later this year.
  23. Bradderz_1988
    4,029
    286
    059 141 031 M - S4 friction disc
    077 141 117 C - vw lt pressure plate
    Think thats them
  24. Bradderz_1988
    4,029
    286
    This is what it looked like when i first got it with the silver wheels.
  25. EvilSnow
    596
    33
    I love black B5's man
  26. PaulJC84
    PaulJC84 Owner
    2,939
    25
    Here was mine from the advert and when I borrowed some boleros.
  27. Bradderz_1988
    4,029
    286
    Did you have this up for sale in 2009 ?? Im sure this is the one i enquired about before i got mine ?
  28. PaulJC84
    PaulJC84 Owner
    2,939
    25
    No I have had it for 13 years next month and never advertised it for sale. Did think about selling to a friend about 5 years ago but changed my mind.
  29. Bradderz_1988
    4,029
    286
    Hmm must of been a dodgy add as im 99% positive that was the reg on the car i looked at and i wondered why he wouldnt answer the phone the day i was meant to come and look at it
  30. PaulJC84
    PaulJC84 Owner
    2,939
    25
    Gosh that is worrying!
  31. Bradderz_1988
    4,029
    286
    Got the bits back off my mate today who had them shot blasted for me, going to weld the back plates on in work maybe this week or next then see about getting them galvanised and powder coated.
    I also need to get a few things sorted on the S3 aswell wheel alignment, rocker gasket and wheel bearings mainly.
  32. Bradderz_1988
    4,029
    286
    It pains me to say it but the TQS is going.
    If anyone is after anything let me know il get back too you. Most items will be collection only due to size/weight.
    Just a few things
    Recaros - £450 (average condition, drivers lumbar motor doesn't work includes door cards/armrest)
    T28 turbo hardware kit - £225 (no turbo, atp coated manifold/ported needs matching to cylinder head if head being ported, 5 bolt to vband, 3" vband ATP Down pipe mates to existing 3 bolt downpipe so cat needs mounting elsewhere if wanting a cat, assortment of oil &coolant lines and fittings)
    ABF forged crank - £100 '058 1.8T stroker crank' triggerwheel bolts welded
    Milltek non-res 2.75" full system - £300
    OEM xenons - £200 ones had oem repair tabs fitted great condition
    B6 S4 front brake kit - £250 (nearly new caliper hard lines, HEL 'red' lines)
    S4 B5 uprights - £50 no bearings installed comes with hubs
    Rear uprights - £50 nearly new skf bearings
    Facelift S4 300mm rear brakes - £200 (calipers nearly new seals/boots, carriers, trig brackets, custom HEL lines, nearly new pagid disc possibly benefit skim to remove corrosion and nearly new pagid pads)
    Apikol rear diff bushes blue in crosember painted red - £60
    034 track density 5 speed box mounts - £80
    034 snub and bracket - £70
    AJL/AEB big port bare cylinder head 180k - £75
    older style flat 1.8T rocker cover shaved and painted in red - £30
    AJL/AEB block 180k - £50
    Topran Oil pump - £25
    front and rear shot blasted subframes £50
    Rear shock turrets - £100 shot blasted and had plates welded need powdercoating.
    S4 facelift rear bumper bought brand new few years back painted twice - £200
    S4 front bumper and modified crash bar - £50 in progress off modding needs a headlight washer has no fogs rivet holes from cupra splitter being fitted.
    S4 door mouldings and skirts - £100
    TQS clocks - £50 usual dead pixels
    Sports wheel with airbag - £30 needs new sports badge as scratched
    Passat B5.5 wiper arms and blades - £45 nearly new
    Rear arms/ links all recently had bushes before removed £150
    Rear subframe brake hardlines - £60 bought brand new from TPS
    Gearbox 5 speed painted black - £75
    Rear diff painted black - £50 DAJ
    Aeb/ajl Big port inlet painted black - £30
    Abs ecu - £50 unknown condition never had any issues
    Front driveshafts - £50 new outer boots and cv joint on o/s
    CL pump - £50 with upgraded pump motor
  33. Avatar
    snack-media
    Advertisement
  34. PaulJC84
    PaulJC84 Owner
    2,939
    25
    Gosh this is a surprise!
    Everyone is throwing in the towel who had a bunch of mods.
  35. EvilSnow
    596
    33
    I'll probably have a few bits off you Brad, have you got the me7 conversion?
  36. RaulQTS
    RaulQTS Registered User
    202
    10
    I am interested in the following
    Topran Oil pump - £25 is this new ?
    Where are you located
  37. RaulQTS
    202
    10
    Did you have any engine parts for sale forged rods , pistons bearings etc
  38. superkarl
    superkarl MAN OF STEEL
    10,037
    2,676
    I would like the AEB inlet manifold. Is this postable for you?
  39. Bradderz_1988
    4,029
    286
    Sorry guys if you can text/whatsapp me what your all after on 07930429851 il get back to you.
  40. Bradderz_1988
    4,029
    286
    Give us a text on 07930429851
  41. Bradderz_1988
    4,029
    286
    Front bumper provisionally sold
    Apikol bushes/crossmember - sold pending payment
    Can i just stress that im really looking to get items collected in person( no couriers) i can do it on some of the smaller stuff as and when i get to the car as im not at the property anymore and she doesnt want me seeing the kids just yet, so collection would have to be arrange with myself way in advance so i can arrange with her when suits i may even be able to borrow a van to grab some of the larger stuff and take it to my work for you to collect
  42. Oranoco
    4,026
    417
    Doesn't sound good at all mate. Hope it all settles down for you :-(
  43. Bradderz_1988
    4,029
    286
    @Oranoco Cheers mate il be alright once i find my feet again then might do something with the S3 or look at a B5 again.
