So my S1 has the standard sound system, I've found a Bose system or two for sale on Ebay.... is it worth it??, does the S1 already have the wiring installed... as the systems I have seen do not come with wiring looms?? and lastly, does anyone have any idea how easy it would be to install?? Thanks
It's a better system than the standard setup. There is no wiring fitted in any VAG car for any non-factory fitted feature. In a non Bose system the speaker wiring goes to the head unit, on a Bose system it goes to the amp in the boot. You'll need a compatible head unit and you'll need the MOST cables from head unit to the Bose DSP/Amp. you'll have to take the door cards/rear door/rear quarter cards off, to change the existing speakers and fitted the additional ones (rear seats have to come out to get some of the trim off). Once done you'll need someone with VCP to modify the head unit and code. The coding can be done with VCDS but not the re-paramterisation. If you have to ask how hard then I wouldn't even attempt it tbh. Upgrading to the Audi Sound System is relatively easy in comparison but you still need door cards off and have to add wiring for the centre speaker and subwoofer and modify the head unit if it supports A.S.S (I've done this on mine). Hope that helps?
Yes, it is worth it. I have had the standard system and the Bose is excellent! G Sent from my iPhone using Tapatalk
I think Phazer has really answered your question. However you may find this recent article of interest: https://www.audi-sport.net/xf/threads/front-speaker-upgrade-sportback-full-info.412017/
