Boot Won't Open Via Fob
jdw88rm
Hi guys,
The boot on my 1.9 TDI won't open through the fob and can only be opened manually. I'm sorry if this is a stupid question but what could it be? Easy to fix? Expensive?
Cheers guys
barkclark
I think I have the same problem!
barkclark
Probably the button not working just keep pressing and lifting, also it may sound stupid but check the extra dead lock thingy isn't locked.
I think it's my button that isn't working. Should the button unlock the boot if the car is locked?
My old b5 2.5tdi had two separate buttons, one worked the other never did. The boot won't open by pressing the button if your car is locked.
Welshquattro
My unlock button opens all door and tailgate. The middle button does nothing at all. My avant doesn't have a manual lock on the tailgate.
barkclark
Should the boot pop open when the button is pressed then? Otherwise what's the point in the button?
barkclark
i guess there is no point to the button haha
jdw88rm
Yes the boot button on the fob should open the boot if the car is locked. My problem is, I have to stick the key in and open it that way!
barkclark
There's two different problems on the go here I think haha
barkclark
My boot won't unlock with the specific boot unlock button (I think). Should it pop open?
Welshquattro
Also helps if put if it's a Avant or saloon!
jdw88rm
Its a saloon. The button on the fob doesn't do anything. It USED to pop the boot off the latch and flash the lights. To open I have to physically use the key to open it up.
Welshquattro
I think you can isolate to tailgate from the rest of the central locking system with the key but not sure if you can do it with a saloon!
quattrojames
Moderator
Staff member
Moderator
I think there are two solenoids in the boot lid, one will unlock it, one will pop it off the latch, sounds like the latch solenoid is broken. I think the p/n is in the sticky, I will check.
WOLF
mine is an avant,pressing unlock opens the 4 doors but when you try lifting the boot it doesnt open.
sammi
I have a cab and I'm sure it's the same as my old saloon.mine used to intermittently play up touch wood the following works though now!.... I have to use the car unlock button to unlock the car then push and hold the boot button for a couple of seconds then the boot pops open a tad. The only other way I can unlock my boot is two clicks on the key fob un lock button, first click unlocks drivers side, 2nd click unlocks pass side & boot then u can manually unlatch it! Hope that makes sense :) if none of them work as above I guess you need to sort the solinoid.
Chrismawa
Keeping the button held down on my Avant pops it open now I've had it unlocked on VCDS. Before if i pressed it, it would just unlock it.
barkclark
I didn't realise that you had to hold the button down to pop the boot! Just tried it and it works for me when my Avant is fully locked or unlocked!
