I guessing the motors as the struts were replaced a while back as it was int not opening had to click twice and been gradually getting worse. If you gently help it up it seems to work fine. I do use my boot a lot though.
I got a set of used motors as I retrofit the electric tailgate. You could try and find some on ebay. I've got one motor for sale, but cannot remember which side, would need to check tomorrow.
With very light help it goes up fine so maybe it is the Rams they were a pattern part and not that expensive so may try that first.
I assume they have different part codes to the non motor driven part.
Oops that was today just sent message.
Fitted the new ones and so much better the boot actually opens fully now so I don't bang my head. Bolts were slightly loose on mine too. Bit of a clean up on the knuckle and really had to push the boot up without old strut the other side to get it on.
Lubricated the lock mech and perfect now. Thanks
Works better but still not perfect.
When you open it it now only opens a small amount just open an inch and you press again and it will open fine all the way.
Also sometimes when it closes it starts to close then stops and returns back to fully open.
Weird
Only option now is the motors, it could have been they have been working harder than they should have due to the failing struts. I know I've got one motor you can have for £80 posted.
