GarrettVr6
so ive been trying to solve this problem for 2 weeks now I scanned the car for the CEL and got a p0237 and some times p0236 codes and I’ve replaced the boost sensor and still have gotten the code, I’ve tested the system for boost leaks and everything is holding pressure, now I’m thinking the pcm could be fried because I forgot to plug the boost sensor after I was boost leak test and went driving and it was raining and I had a cel then I remembered I forgot to plug it in I pulled over plugged it in the car worked fine for a few days then has been limp moding ever since, I’m just wonder if that would fry the pcm wiring for the boost sensor and would make it keep throwing the cel. I’m just frustrated and wondering if it would be worth it to buy a new pcm, here are the codes and what vag com says
