Boost pressure sensor location? Cr 170 tdi common rail
Lukeyboi89
Nottingham
Hi guys,
I bought a dtuk tuning kit for my 2010 cr 170 quattro, but I can't find the Boost pressure sensor which I need to plug this dtuk into?
It's a 4 pin plug, I can see one between the alternator and the Boost pipe connecting to the throttle body, but it's behind some hard line ac pipes and is inaccessible, also it doesn't feed into the boost pipe so I don't think that's the correct sensor.
Any help appreciated, lots of googling and a3 Facebook group noobs were not helpful...
Any luck with this as have just bought the same box and can’t see the boost sensor,cheers
You access it from the underside, remove tray and you'll see (just) the intercooler pipe and the sensor is on that, little hard to get to if you don't raise it off the ground slightly, location is dependent on engine code . But pretty sure that's where you'll find it
