Boost Pressure Regulation
Donfero
facing the same problem again, this time I'm ready to sell the car!!!
1 Fault Found:
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 179370 km
Time Indication: 0
Freeze Frame:
RPM: 2916 /min
Load: 52.1 %
Speed: 122.0 km/h
Temperature: 87.0°C
Temperature: 27.0°C
Absolute Pres.: 900.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
Any thoughts where I should start?
NHN
Site Sponsor
On which engine?
can31
Boost leak. Look beneath your car, check intercooler piping, if there is some oil in connections then you what is it. Maybe your I/C has leak or some of the PCV piping.
Sent from my CLT-L29 using Tapatalk
Donfero
I'm having problems building boost, but then suddenly the car has power!!
can31
Does it feel like pumping boost? Like you have variations in power?
can31
I'm almost 100% sure you have a leak. Probably on I/C.
Donfero
Checked for leaks, did have a few small ones but still the same problem, struggling to build boost but once built it would go to 1.7. Could it be the DV? I suspect I have a copy of the GFB DV+ as it wasnt ordered from their website.
Sent from my TA-1004 using Tapatalk
can31
If you have tuned car, then dv is also probably the cause.
Donfero
No issues with the DV, im only having this problem while going uphill when the engine is under load!!
can31
Have you checked the cam follower? Do you have a vcds to record fuel pressure?
Donfero
Cam follower is good. Currently having the cylinder head removed to change valve stem seals, found oil on the injectors.
Donfero
Found a leaking DV, engine head going back in tomorrow with a new DV. Hope thats the problem.
