Hey guys,
As the title states I'm getting boost cut after 5700-800rpm past 2nd gear. I know the turbo doesn't have enough air but it doesn't even try to boost it releases all pressure as per VCDS. I have around 155g/s mag flow and a slightly torn crankcase breather pipe. What I want to know is the boost cut because of the low maf reading and torn hose or just the lack of air from the turbo so as to know what to look for. My BOV is from a Saab Aero 260hp (presumably able to hold more boost) and I tried another spare n75 which improved spool and high rpm by around 200-300rpm. Not sure if my explanation is clear.
Thanks in advance!
Thanks in advance!
