  2. Dismiss Notice
Bobby Singh A4 3.0 TDI build thread
bobby singh Jul 14, 2015
  1. The Black Panther
    The Black Panther Adventurer !
    430
    112
    43
    I agree he talks some pash does that mr Xjay :) But equally forum rules state no personal abuse. Re read them again mate. Plus your blocking up the thread with nonsense.
  2. Avatar
    snack-media
    Advertisement
  3. Roadrunner146
    Roadrunner146 Registered User
    367
    82
    Boring
  4. mdmay
    mdmay Registered User
    130
    37
    Admin please delete my posts
    Sent from my SM-G955F using Tapatalk
  5. Nicwike
    Nicwike Registered User
    10
  6. Nicwike
    10
    Hi Bobby,
    I was hoping you could tell me the correct model of eibach springs for my car.
    2009 a4 3.0tdi s line.
    Ive had H&R springs for a year and they are just too low (im getting a lot of rubbing after installing fresh tyres last week). -steeper sidewall..
    I have found this set and think they are the correct ones.
    Is this the model you used? your height looks pretty good.
    biscuit-a3 likes this.
  7. Nicwike
    10
    • Performance Springs Pro-Kit E10-15-011-04-22 Audi A4 Avant (8K)
  8. Gazwould
    Gazwould Registered User
    7,754
    3,136
    Correct .
  9. kiros_red
    kiros_red Registered User
    Is not correct model? [​IMG]
    Envoyé de mon SM-A520F en utilisant Tapatalk
  10. Gazwould
    7,754
    3,136
    Fronts are correct , can't see last part on rears is it.... 03HA ?
  11. kiros_red
    Part rears is 01HA is good?
  12. Avatar
    snack-media
    Advertisement
  13. kiros_red
    Audi a4 b8 3.0 tdi 2009 avant
  14. Gazwould
    7,754
    3,136
    Rear Avant is 03 , rear Saloon is 01 !
  15. kiros_red
    with the number part of the springs I looked on the net of audi a4 b8 avant
  16. Gazwould
    7,754
    3,136
    What year , engine code and horse power is your 3.0 tdi Avant ?
    Nicwike likes this.
  17. kiros_red
    Audi a4 b8 sline plus 2009 ccwa 3.0 tdi 239hp
    Nicwike likes this.
  18. Gazwould
    7,754
    3,136
    100% your rear springs ending 01HA are for a saloon .
    03HA are the correct Eibach Pro for your Avant .
    Nicwike likes this.
  19. bobby singh
    bobby singh BSR Gold Supporter VCDS Map User
    1,009
    792
    January 2018 505hp / 980nm
    Well guys managed to hit my target of 500hp
    So what’s changed? As you know my s200v has been put up for sale to make way for unique turbo.
    EFR7670 with S300v housing :) its a watercooled roller bearing turbo with really nice wheels -
    CW:76/57
    TW: 70/61, gamma-Ti alloy, lower density (and thus inertia) than conventional Inconel alloys
    I've been driving for approx a month tuning it and trying to get it right for a power run. Its been task to balance
    spool Vs surge - for example more spool is possible but then get surge so the short term workaround is to run less
    boost. Long term would be to leak off some air via ECU controlled valve.
    So yes it does have lag but it still have same torque as a stock 3.0tdi @ 2.2k in its current form.
    Dyno
    We turned up on a BMW day ;)
    Smoke test Video:
    captured by Jay
    The turbo is really a monster and still has more scope, but I'm out of fuel. I guess with larger injectors 550hp would be on the cards.
    EGT's - 900deg
    Stock engine (apart from valvesprings)
    Stock exhaust apart from downpipe
    Stock gearbox
    No smoke
    Bobby
    DrStrange, Rhyso, TimberVD and 8 others like this.
  20. bobby singh
    1,009
    792
    Mr Audi - you really put some effort in :)
    Bi turbo - yes they are lovely cars and the low down torque is always nice. In fact from all the turbos I've had I would say the best street turbo was the 2260 hybrid for wider power band on a 3.0tdi
    However, not everyone can afford one and there are more single turbo 3.0 TDI's on the road so it made sense to push the boundaries on this platform.
    I'm no diesel god but I have learnt a lot from own project cars over the years which means I know some facts rather than just following what people say.
    You are correct I do not believe you have 450hp hence why I asked number of times if you have been to a dyno other than the tuners one.
    Or at least post some 100 to 200km times with vcds.
    The fact is bi turbo engine even with 2.2k rail pressure run 900deg (this is max safe limit before fuel is taken out by the ECU to save itself) which results in around 420hp / 900nm.
    Next time I get one in I'll grab the logs and post them.
    Final point you mentioned in one post you can get 450hp in a bi turbo with dpf - where is the evidence? I would love to see that.
    But maybe open another thread and we can continue on that rather than getting side tracked with my build thread.
    Bobby
    martinivw, aqibi2000, Rhyso and 6 others like this.
  21. bobby singh
    1,009
    792
    I'll get you this tomorrow - The box is in the garage so should have the part number etc
    kiros_red likes this.
  22. barkclark
    barkclark Registered User
    1,042
    294
    This. Is. INCREDIBLE!!
    Loving your work as always
    bobby singh likes this.
  23. barkclark
    1,042
    294
    I like how my post was the 500th, just to match in with you breaking the 500hp barrier!!
  24. bobby singh
    1,009
    792
    Haha
    mdmay likes this.
  25. mdmay
    130
    37
    Look forward to seeing you soon and the beast when the young one brings his 535d to see you
  26. bobby singh
    1,009
    792
    Likewise mate :)
    Chassis is alittle nervious now - each gear change brings a huge rush of power and in the wet...well lets just say traction stays on all the time.
    Horia, kiros_red and Roadrunner146 like this.
  27. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User
    7,419
    3,715
    Top job Bobby, Pity you didn't crack the 1000Nm as well as 500bhp but I am sure you will get there once you sort the surge issues.
    I presume the compressor housing you are using already has a ported shroud which will help to stop surge.
    I see you have the speed sensor connected has that been useful in tuning, I suppose it gives you an idea of where you are on the compressor map and how much you have left in the turbo.
    Looking at the compressor map for that wheel seems to be capable of around 60Lb/min plus at around 2.5 bar of boost. I could see you running more than that as well as the wheel seems good for 3 bar, Not surprised you changed the valve springs.
    martinivw, TimberVD and bobby singh like this.
  28. kiros_red
    Congratulations, your car is a monster ...
  29. Devilz
    Devilz Active Member VCDS Map User
    440
    128
    43
    505hp
  30. The Black Panther
    430
    112
    43
    Its fake ! ! Kidding ! :) Well done Bobby mega :sign omg:
  31. The Black Panther
    430
    112
    43
    I don't want to fill your valuable thread with BITDi stuff and it is great to see so much ingenuity be applied to the single turbo units congratulations. Its of tremendous value to a lot of people and really fun to read about. It would be good to one day see you take on a BITDI as a project car. I don't know if that will happen but i know at the moment with my knowledge and from the knowledge out there ( i have asked and had the conversations but none off tuners are working on anything ) no one has taken the cars past STG3. If its possible to go to the figures you have on your car at the moment a BITDI Hybrid would be very interesting indeed. See multiple SQ5 and BITDI tunes on this thread DPF removed and DPF intact https://www.facebook.com/JDEngineer...xOqPdH3gjZ7Zg_YfuJH669QngzqLdMeCTI73ROikHVD1s
    Also you ll find a few 1000 nm plus A8 4.tdi !! takes a while to find them you have to scroll scroll scroll
    Later . . .. . . till the next time :sign imnew:
  32. The Black Panther
    430
    112
    43
  33. Avatar
    snack-media
    Advertisement
  34. Horia
    Horia Registered User
    15
    Bravo Bobby, Bravoooooo!!!! :beercheers::grinning:
  35. Nicwike
    10
    Thank you so much.
  36. arad85
    arad85 Registered User
    1,081
    431
    Awesome job Bobby!
  37. bobby singh
    1,009
    792
    Thanks Karl - yes housing has anti surge, but the unit pushes a lot of air so I can only think of bleed the air out to prevent surge - maybe like a egr valve.
    Speed sensor is working but I don't believe the readings voltage output is too low - I need to test it.
    You next :)
    Horia likes this.
  38. V6_Man
    V6_Man Moderator Staff Member Moderator VCDS Map User
    6,988
    14,082
    @bobby singh it’s stunning numbers mate . You need to come up with a plan for The CVT box on my diesel. The Petrol is now returned to the dealer I bought from as it had too many issues. I will be waiting for a text / message from you buddy.
  39. desertstorm
    7,419
    3,715
    The output of the speed sensor is a frequency output not voltage.
    http://www.turbos.borgwarner.com/files/pdf/efr_turbo_technical_brief.pdf
    Page 67.
    I have looked into the EFR turbo's as a possible choice if I go to a big turbo on the TT. I thought the 7670 had a BOV on the compressor cover that is used to recirculate air into the intake. some kind of Arduino project taking engine RPM, boost and MAF signals to limit the boost in higher gears when the turbo is spooling. Try and keep on the right side of the surge line.
    aqibi2000 likes this.
  40. bobby singh
    1,009
    792
    Sure I have freq to voltage convertor which is used as 0 to 5v input into the ECU so I can log it ;)
    Yes BOV it did have but I blocked this off - EGR would offer much more nicer control but would be a pita to map.
  41. holmefield
    holmefield Registered User
    633
    79
    ****** hell bobby singh thats ridiculous power from a single turbo 3 litre TDI, well done, is there any chance you can map my 245bhp A7
    I have a DTUK tuning box on @ the mo and was happy @ around 280bhp but i recon you could map mine to 300bhp easy.
    It must feel like a monster on the road @ 500bhp is it not trying to pull to one side when you floor it?
  42. GarethS4
    GarethS4 Registered User
    122
    34
    Wow that’s some job you have.i only drive trucks that supply 90% of the everyday items used.its a sh1t worthless job unlike yours.
    xpoweruk likes this.
  43. mdmay
    130
    37
    This man is a legend. Your employment contribution is extremely important
    GarethS4 and Seanchadwick2k3 like this.
