  2. Dismiss Notice
Help Please Bluetooth streaming Audi A4
A4newb Jul 23, 2019
  1. A4newb
    A4newb Registered User
    10
    Hi,
    New Audi owner after having BMWs for a long time. I have a 2010 Audi A4 S Line special edition with the Concert/B&O sound system.
    It has Bluetooth only for phone calls and not for streaming. A previous owner has fitted some kind of cable that seems to go from the cd changer and connects to an iPhone lightning cable. I've attached a pic.
    But basically what I want is to stream music via Bluetooth as I'm an android user or failing that some way of having 2 cables that I can switch over as the wife is an iPhone user.
    In the pic. The white bit has a male lightning connector and the black cable is just an extension. So it's a female iPhone to male iPhone lea
  2. Avatar
    snack-media
    Advertisement
  3. forty3
    forty3 Registered User
    432
    182
    43
    Retrofit 3g+ MMI or look at something like tune2air
  4. A4newb
    10
    So for tune2 air you need the AMI port. Is that the thing that has been fitted in the picture?
  5. AndrewW
    AndrewW Registered User
    234
    225
    43
    The AMI port is the bit inside the glove box that the AMI->lightning cable is plugged into.
    You can buy a AMI->A2DP Bluetooth adapter, there’s lots available, which allows you to connect and stream to the car from just about any device.
  6. A4newb
    10
    Haha. Amazing. Didn't know you could open that thing. Woohooooo
  7. AndrewW
    234
    225
    43
    Also, there seems to be some bluetooth dongles that only work with MMI kits, as yours is a concert (like mine) just make sure it’s compatible with concert / non-MMI before you buy
  8. briceportier
    briceportier Registered User
    186
    67
    I have one of these for sale: amazon.co.uk/dp/B00R2HZ1XU
  9. feva
    feva Registered User
    932
    591
    93
    As an android user I've use one of these.
    Plug in cigarette socket in arm rest [​IMG]
    Sent from my SM-N950F using Tapatalk
    Sherv likes this.
  10. Sherv
    Sherv Registered User
    183
    35
    I have a device similar to feva.
