bleeding clutch fluid
Boggle
hi peeps i have had a look but no luck in finding what tool i need to bleed my clucth fuild
MUSH
MUSH Developments Ltd.
What car?
If its an s3 then all you need is a 9mm spanner for the slave cylinder bleed nipple. If its an A3 then itl be the same or maybe an 11mm? Been a while since ive done one of those... None the less just basic tools
Boggle
sorry i was rushing when i wrote this post its a a3 and its a external slave cylinder in the hanyes book it tells me i need to have a vacum sort of tool so should i just undone the nipple and pump the clucth
MUSH
Yep just bleed the circuit using the pedal whilst opening the nipple.
jay1601
you can buy a bleeding pot from halfords about £5.
just slack off the nipple get someone to pump the clutch pedal until no air bubbles comes out then to the nipple up. top up fluid if needed
simple job
MUSH
Pressure bleeder is the answer here then, theyre reasonably cheap £15ish iirc. Will have it done in a few minutes
