Bilstein B14
clintonbragg84
Has anyone fitted these and have pics or would recommend
Sent from my Pixel XL using Tapatalk
General day to day but don't want to spoil the ride comfort, wanna bring it down by 20mm
they will probably be a bit to sporty for daily use , B8's are very good.
As above , overkill for the road .
What suspension do you currently have ?
I've got standard but rear suspension has just gone so looking to replace with something better
Eibach Pro with Bilstein B8 shocks
( B12 kit ) max or for added comfort Eibach Pro with Bilstein B4 shocks .
Reactions: clintonbragg84
what variant do you have chap, also by standard do you mean non s-line setup.
so already about 20-25mm lower than standard ride height, and you are looking to go another 20mm , yes.
do you want a pre-set ride height by using fixed length damper /spring setup or want to use coilovers to set the height yourself.
As mentioned the B14 kit is probably a little handling orientated for everyday road use, maybe consider something like the ST by KW kit.
Damian @ DPM Performance
