  2. Dismiss Notice
Bi-xenon headlight problem
Tendaimwari Sep 3, 2019
  1. Tendaimwari
    Tendaimwari Registered User
    166
    I recently replaced the xenon bulb and a few days later condensation built up in the headlamp unit and the new bulb no longer illuminated. The day was hot so removed the fog light and let it air out and re-installed the xenon access panel. Now every time the headlights come on there are multiple warnings and the 30A fuse keeps on blowing.
    Yesterday I replaced the fuse cleared all faults and switched on the headlights. The following is a copy of the full scan. The DRL does work when the fuse is replaced so I do not think it is the DRL module that is faulty
    BTW, based on previous scan the longer the car is driven the more fault codes are logged, which I assume is related to the central control module J393.
    Could it be the xenon ballast?
    Code:
    Monday,02,September,2019,16:40:25:50105
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
    Data version: 20190529 DS308.0
    [URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
    VIN: WAUZZZ4G5DN007153   License Plate: EM866MR
    Mileage: 123151km-76522mi   Repair Order: 02092019
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3B 3C 42 44 46 52 53 55
              56 5F 62 72 85 8B 8E 8F 90
    VIN: WAUZZZ4G5DN007153   Mileage: 123151km-76522miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0002
       Revision: 53H37---
       Coding: 12254012056601020000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
       ROD: EV_ECM30TDI0114G0907401Q.rod
       VCID: 313C1F2421A5611F757-8064
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217)       Labels:| 0B5-927-156.clb
       Part No SW: 4G1 927 156 T    HW: 0B5 927 156 J
       Component: 0B5 30 TDIRdW H01 0003
       Revision: --H01---    Serial number: 0000000713
       Coding: 000001
       ASAM Dataset: EV_TCMDL501021 001009
       ROD: EV_TCMDL501021.rod
       VCID: 3E263418E0FB8E67F85-806A
    1 Fault Found:
    7980 - RPM Signal from ECU
              P0726 00 [047] - Implausible Signal
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 9
                        Reset counter: 40
                        Mileage: 123091 km
                        Date: 2019.09.01
                        Time: 11:09:29
                        Engine speed: 1374 /min
                        Transmission input speed: 1374 /min
                        Transmission output speed: 337 /min
                        Engine torque: 220 Nm
                        Transmission fluid temperature: 64 °C
                        Accelerator position: 30.4 %
                        Clutch status: Kupplung 2 kann Moment übertragen
                        Unlearning counter according OBD: 40
                        Engine speed: 764 /min
                        Transmission_rotational_speed_working_cycle-Data: 0 /min
                        Transmission input speed: 764.00 /min
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
       Component: ESP PREMIUM   H09 0361
       Revision: --------    Serial number: --------------
       Coding: 27A68701E465E180DB00
       ASAM Dataset: EV_ESPPremiAU57X 004028
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 382A2200C2DFB057329-806C
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
       Component: BCM2 2.0      H32 0421
       Revision: 00002001
       Coding: 01B93046000000000000
       VCID: 77A8E13C8FC17F2FFB3-8022
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 2312000096367014
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 214
                        Mileage: 123111 km
                        Time Indication: 0
                        Date: 2019.09.01
                        Time: 12:09:57
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
       Component: KLIMA 2 ZONEN H11 0070
       Serial number: 24051200110078
       Coding: 3622000825
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       ROD: EV_AirCondiBasisUDS_002.rod
       VCID: 609AAA603ACF9897AA9-8034
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0130
       Revision: 20012002    Serial number: 00000001504642
       Coding: 2600A01040349FE28181008300001D0CCF9DC70827090201000004606100
       VCID: 6E86C458F09B3EE7285-803A
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 120405  H35 0080
       Serial number:         120417003453
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 20280615
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 21 05 2012  00000780
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H03 0002
       Serial number: 18688A26000000000001
    2 Faults Found:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                012 - Electrical Fault in Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 214
                        Mileage: 123100 km
                        Time Indication: 0
                        Date: 2019.09.01
                        Time: 11:19:00
    01516 - Terminal 30; Left
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 214
                        Mileage: 123100 km
                        Time Indication: 0
                        Date: 2019.09.01
                        Time: 11:19:00
    Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061213301742
       Coding: 88EB08
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       ROD: EV_EPHVA18AU57X0000_003.rod
       VCID: 77A8E13C8F417F2FFB3-8022
    Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H17 0400
       Serial number: 00000000000000
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 280AF240127F20D7A29-807C
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H43 0040
       Revision: --------    Serial number: 003JG008MG20
       Coding: 30323436313330303539554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 36362C38C8CB4627205-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB405R1C4LI1P1M
       Crash sensor for side airbag: front passenger side:
       Serial number: 3585HRB40671CAICBH68
       Crash sensor for side airbag: rear: driver side:
       Serial number: 3515JRB404P184COA0KB
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 3525JRB405F18E5EG1Q9
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB400K4UE2089IN
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB400I4UE20M1DN
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H03 0005
       Revision: --------    Serial number: 90372LEG000K5
       Coding: 0000FD
       VCID: 3728213CCF41BF2F3B3-8062
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0009
       Serial number: 30 03 2012  D0047994
    1 Fault Found:
    00457 - Central Electronics Control Module / BCM (J519)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 214
                        Mileage: 123111 km
                        Time Indication: 0
                        Date: 2019.09.01
                        Time: 12:09:58
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 983 J    HW: 4G8 920 983 J
       Component: TDieGb Acc    H79 0515
       Revision: 28460207    Serial number: 658080512596016
       Coding: 238F10000F512600010000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU57.rod
       VCID: 3C223E10F6E79C77D61-8068
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000535507
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001013
       ROD: EV_GatewPkoUDS_001_AU57.rod
       VCID: 70BADA20EA2F28173A9-8024
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790407372
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 27021200000000000355
    1 Fault Found:
    5057 - Body Control Module (Central Electric)
              U0140 00 [008] - No Communications
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 214
                        Mileage: 123111 km
                        Date: 2019.09.01
                        Time: 12:09:56
                        Voltage terminal 30: 12.1 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 32 °C
                        System status: A-/F-CAN / FlexRay_active
                        IN ESP_standstill flag: standstill detected
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status via CAN: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0009
       Revision: --------    Serial number: EJ1BPA42050J7V0
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: 2D0403543D9D05FF51F-8078
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH01 0040
       Revision: 00H01000    Serial number: 6PZ 010 287-03
       Coding: 0001102
       VCID: 303A1A20262F68177A9-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H01 0040
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F22.05.1200H010003CF24174ÿ
       Subsystem 4 - Serial number: F24174ÿ
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0506
       Coding: 011F16005C01628002080013
       VCID: 45D45BF485ADDDBFB9F-8010
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0027405788
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323E102824A35A070CD-8066
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0176441947
       Coding: 013B062220B90080832009042001040F0000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    2 Faults Found:
    01517 - Control Module for Trailer/Towing Sensor (J345)
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 174
                        Mileage: 123100 km
                        Time Indication: 0
                        Date: 2019.09.01
                        Time: 11:20:44
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 214
                        Mileage: 123111 km
                        Time Indication: 0
                        Date: 2019.09.01
                        Time: 12:09:57
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0506
       Coding: 011F16005C01628002080002
       VCID: 46D65CF8B8ABD6A7B05-8012
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000354291
       ASAM Dataset: EV_ParkiBrake 001027
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B000D4C03890BCF4FB-807E
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Component: ....LWR12.... H02 0013
       Serial number: 120521-0001-032
       Coding: 1122A6101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C020E5006870CF7461-8078
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H60 0133
       Revision: AB001007    Serial number: 230E.0C7565493
       Coding: 010003020100000001
       VCID: 280AF24012FF20D7A29-807C
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 H
       Component: H-BNT-EU      H49 1034
       Revision: --------    Serial number: 190EY0C7504447
       Coding: 050101010003E9ED3D90CF3E00000003000001000000000000
       VCID: 313C1F242125611F757-8064
       Subsystem 1 - Part No: 8R0 060 884 ED
       Component: EUR 2017  2402
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC9401CE6H
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Component: E380 BDT C7  H11 0204
       Serial number: 90349LEM000LF
       Subsystem 4 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
    1 Fault Found:
    03623 - Invalid Security/Release Code
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 173
                        Mileage: 123089 km
                        Time Indication: 0
                        Date: 2019.09.01
                        Time: 11:00:43
                 Freeze Frame:
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
    Address 62: Door, Rear Left (J388)       Labels: None
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HL        H03 0506
       Coding: 010F14004001628002080002
       VCID: 49CC57C4A9B539DF5D7-801C
    Address 72: Door, Rear Right (J389)       Labels: None
       Component: TSG HR        H03 0506
    Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H25 0038
       Revision: --------    Serial number: 262130025421000
       Coding: 6A060000
       ASAM Dataset: EV_OnBoardCamerDPC 001007
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2616FC78186B36A7905-8072
    Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
    Address 8E: Image Processing (J851)       Labels:| 4H0-907-107-V2.clb
       Part No SW: 4G0 907 107 D    HW: 4H0 907 107
       Component: BV-SG         H30 0038
       Serial number: 005000052005127
       Coding: 04C238181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 2708F17C1F612FAFAB3-8072
    Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Component: RGS-VL        H13 0080
       Coding: 0066E608031F037E070308004240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
    Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
       Component: RGS-VR        H13 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    End----------(Elapsed Time: 02:22, VBatt start/end: 14.2V/14.5V)-----------
  2. Avatar
    snack-media
    Advertisement
  3. Mo-S3
    Mo-S3 Registered User
    859
    Check the module that sits under the headlight and also check the power to your J519 as you have a supply issue there
  4. Tendaimwari
    166
    Thanks for the response. I assume that the module underneath the headlights is J343 module and can J519 module be measured via VCDS or do I have to remove trim panels and whip out the multimeter?
