BEX HEAD REPLACEMENT?
BareBack88 Jan 25, 2017
  1. BareBack88
    BareBack88 New Member
    Hi I'm new to this forum so here goes, a spark plug recently sheared off in my head!! (NGK) Nightmare! I have removed the head to find out that 2 of the valve seats have cracked it cylinders 1 and 2!! So I'm going to replace my head, my question is what other head from the 1.8t other than the BEX will fit.
    Cheers any help would be much appreciated
  2. Avatar
    Google AdSense Advertisement
  3. QuattroCalum
    QuattroCalum Well-Known Member saloon Audi A4 Black Edition Saloon Manual
    1,920
    691
    Most of the 1.8t heads will fit, older ones like AEB will fit but don't have the secondary air injection port. The newer heads are known as small port and the older ones are large port. I have an ARY head on my BFB bottom end, ARY is from 1,8t Audi TT 180hp.
    http://www.ebay.co.uk/itm/Audi-A4-B...abd95fc&pid=100005&rk=1&rkt=6&sd=162360641968
  4. BareBack88
    Cheers that's a big help I'll get searching
  5. BareBack88
    So will the AMK fit out of the cupra r just found a complete head that's all cheers
  6. QuattroCalum
    1,920
    691
  7. BareBack88
    Ok thanks thats not a issue as I have no sai or cat I have removed them both, it needs a map from removing them anyway engine management light on does that head have vvt?
  8. QuattroCalum
    1,920
    691
  9. QuattroCalum
    1,920
    691
  10. BareBack88
  11. QuattroCalum
    1,920
    691
    Was it cross threaded or did it just refuse to come out?
  12. Avatar
  13. BareBack88
  14. BareBack88
    It sheared off so the threads were stuck in tried a easy out but it was well stuck it
  15. QuattroCalum
    1,920
    691
    Bad luck that, another £50 for a new head gasket and head bolt set and you're done.
  16. BareBack88
    Hopefully this AUM head will be ok
  17. QuattroCalum
    1,920
    691
    Keep my fingers crossed for you mate.
  18. Stephen Don
    Stephen Don New Member
    Hi I recently purchased a 2004 A4 Quattro Avant 1.8t 190bhp. Was very excited purchasing the car and all I wanted to do was just jump in and drive, unfortunately I didn't do the proper checks and after some inspection I notice that the cylinder head stamp is AUM. My question is, is it compatible with a bex block or would it be a complete AUM engine in my new Audi? What are the pros and cons of any? Car is running fine at the moment just not sure if this work was done recently or not and if my engine is a ticking time bomb, I'm not very mechanically minded so I'd appreciate some advice please
  19. QuattroCalum
    1,920
    691
    Don't worry the heads are interchangeable between all the 1.8t's except the older large port heads (AEB) because they don't have the Saip port (for emissions)
    I have an ARY head from an Audi TT on my BFB engined A4.
    Sent from my ANE-LX1 using Tapatalk
    lowlife89 likes this.
  20. Stephen Don
    Cheers for the quick reply mate and what about bhp? Would there be any difference? And where would I locate the engine number on the block to see if it's still a BEX?
  21. QuattroCalum
    1,920
    691
    No difference at all, it's the ECU that determines power output. I don't know where the engine number is stamped. Pretty common to have the head changed.
  22. QuattroCalum
    1,920
    691
    AUM is used in VW Golf 2001 on.
  23. Stephen Don
    What kind of damage would have to be done in the first place to change the head and is it possible that there is in fact a complete AUM engine in my car?
  24. QuattroCalum
    1,920
    691
    Maybe the timing belt snapped and bent all the valves, it's usually cheaper to use a second hand head rather than replace all valves etc.
    It is possible that it's a complete engine.
  25. Stephen Don
    I'll get someone to have a look it's killing me just not knowing, I'm a bit relieved to hear that the heads areally interchangeable and I may not have been totally ripped off. One more thing mate theres a leak in the coolant system somewhere I know it could be anywhere but if it's a common problem in a particular area of the cooling system where should I be looking?
  26. QuattroCalum
    1,920
    691
    Most common are the rear coolant flange on the back of the cylinder head and the "j plug" that's behind the thermostat housing below the inlet manifold near the front of the block. I would change the j plug anyway.
  27. Stephen Don
    Cheers mate, thanks for all your advice, stress levels have lowered big time, I'll check it out.
    QuattroCalum likes this.
  28. QuattroCalum
    1,920
    691
  29. Stephen Don
    Just out of curiosity what kind of price would you put on my car. 2004 b6 quattro Avant S line, Daytona Grey in mint condition with service history , sun roof, Bose sound system standard, rs6 genuine alloys
  30. Stephen Don
    143000 miles
  31. Stephen Don
    And for oil change should I use 0w 30 or 5 w 30
  32. QuattroCalum
    1,920
    691
    Sorry I have no idea on value.
    Use Castrol Edge Professional 5w30, 5 litres on Ebay for around £30 delivered also make sure you get the large oil filter.
