  2. Dismiss Notice
Best way to dechrome?
DarkShadow May 22, 2018
  1. DarkShadow
    DarkShadow Member
    98
    32
    Hey guys,
    What's your preferred approach to achieve a chrome delete? I'm looking to dechrome the windows and front grille. I would love to have a go myself, any advice?
    marriedblonde likes this.
  2. Avatar
    snack-media
    Advertisement
  3. fafa
    fafa Member
    118
    I had my chrome trim wrapped. I think it cost about £80-100. I’m pleased with how it looks.
  4. Buxton2901
    Buxton2901 Well-Known Member
    1,491
    684
    I may have a black edition grille for sale!
    DM me if your interested :)
  5. marriedblonde
    marriedblonde Well-Known Member
    4,567
    236
    Not that long ago hen I was more enthusiastic about doing things on my cars myself, I bought some decrome tape. Spent the best part of a day stressed, angry, frustrated and decided then that I would only ever wrap a gift if the wife begged in the future. Anything else I would leave to the professionals. Lost a day of my life and could have paid someone £60-70 to do the work.
    To paraphrase the above, don't do it yourself, let someone who does it for a living do it. It'll end up looking better and you wont lose a day :)
    (dont ask me about window tinting, I mean how hard can that be... )
  6. DarkShadow
    DarkShadow Member
    98
    32
    Thanks for the offer but I really don't fancy stripping the bumper off especially for some of the quotes I've received.
    Thanks for the heads up, I have a feeling that's what it may end up like. Plasti-dip solutions looked easy and straight forward but I've heard of being very temporary.
  7. jojo
    29,072
    3,799
    On my car, I went with a black RS6 front grill, replaced the chrome SLine badges on the front wings and the A6 on the boot with black ones from eBay, had my roof rails and window trim wrapped in gloss black.
    Don't know if it's a common thing, or if it's a case of the sun is heating up the vinyl on the driverside, but I've noticed stretch marks on the vinyl wrapped window trim, where the top part of the door seal strikes it when you close the door, both the front and rear doors. It's only obvious when you are close to it.
  8. Sean Byrne
    Sean Byrne Member
    74
    57
    I have used plastic dip on mine, front grill, rear badge and rear diffuser all matt black, and i am delighted with the results, peperation is the key here and a light first coat (60%) hope to do the window chrome surrounds next. will post picture when finnished.
  9. DarkShadow
    DarkShadow Member
    98
    32
    Do report back! I still haven't got around to doing anything
    Sean Byrne likes this.
  10. Jule5n
    Jule5n New Member
    I tri d to plastidip my window trim and it was a ball ache to peel off and took parts with it so ended up wrapping it myself. It takes ages and the rear window section is a nightmare but did it in the end.
    Buxton2901 likes this.
  11. Sean Byrne
    Sean Byrne Member
    74
    57
    Nearly finished the plastic dip on the window chrome, first attempt was a disaster and got the same problems as Jule5 described . re done it again this time not covering the rubber parts and using a scapel and it has turned out really well, am delighted with the finnish. should finnish the other side of the car tomorrow weather permitting, will post picture when completed
  12. Avatar
    snack-media
    Advertisement
  13. Sean Byrne
    Sean Byrne Member
    74
    57
    Finished the de chrome effort on the car with Plastic Dip. Really pleased with the results. the window trim is very tricky to do and as i only done one side at a time i learned a lot on the first go. You can separate the chrome from the rubber surround by inserting light cardboard paper between them and folding the cardboard and masking in to the window pulling the rubber a little away from the chrome to make the plastic easier to peel away. I also did the front grill and back rings and defuser
    Photographs showing the results and some masking
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Roadrunner146 and Spiedhermonkey like this.
  14. Buxton2901
    1,491
    684
    Looks absolutely top banana mate well done. I've just bought some plasti dip to do my wing mirrors. Any tips for spraying the stuff? How many coats did u do
  15. Sean Byrne
    Sean Byrne Member
    74
    57
    When using the plastic dip keep agitating the can every few minutes and store in warm water before use. don't spray to close keep about a least a foot away and just do a light coat for the first coat. i used 4 coats in total. just make sure to area is really clean and dry.
  16. The Black Panther
    The Black Panther Adventurer !
    430
    110
    43
    Bumper takes 30 mins max to remove
    I would avoid plasti cote / dip it will eventually peal off and then. its a whole different barrel of issues
  17. Sean Byrne
    Sean Byrne Member
    74
    57
    If the plastic dip is applied properly its is very durable and should last for years, if you give enough coats in the first place it should peal away very easily if you have problems later, shouldn't be any barrel of issues if done correctly.
  18. The Black Panther
    430
    110
    43
  19. Sean Byrne
    Sean Byrne Member
    74
    57
    That video just backs up what i said. and the guy would use plastic dip again. also he did the whole car, i am only talking about plastic dipping the chrome trim, i found this out when i had to peel all of the first effort on the chrome on one side after the peeling process also took some off the chrome and looked tacky. no bother peeling it all off and then redoing it properly
