Best price on Sachs clutch (2+)
Compkiler
Gfermer
Graeme j at gnj Motorsport got almost all my mods from him awsum guy to deal with best calling up tho maybe get ya a deal
Brodster
Can get a complete Sachs uprated clutch with LUK dual mass flywheel with new release bearing/cylinder and all bolts to go for about £765.
You've also got the Loba/Sachs Stage 3 item with SMF for £880 without the bearing
Helix and SPEC also do good uprated clutches but slightly more expensive.
s3_trev
Northern Ireland
s3_trev
Northern Ireland
I'll give GNJ an email heard good things about them, im going to go for a Sachs clutch with SMF i think
If you use the car every day mate I def would not be going SMF. DMF is the limit of whats tolerable for normal driving IMO.
br20vt
SMF? at stage 2 + not needed at all!
What makes you say this mate? I was in my friends last week with smf and it was slightly more chattery if anything at all, and only slightly heavier on the pedal.
s3_trev
Northern Ireland
I went the DMF route with my clutch upgrade and the weight of the clutch is very noticeable over standard. I also find the vibration has noticeably increased (although I do have uprated engine mounts) so I can only assume the SMF would be even worse in these areas.
S3Alex
Rarely neutral
Gold Supporter
I wouldn't say so.....I think that it's actually dependent on the make etc of clutch itself,rather than SMF Vs DMF.
I've got a Spec Stg3+ in mine,capable of 560lbs,but it's almost stock in feel.
Compkiler
Mine is a Loba with Sachs SMF and mine doesn't chatter at all. The clutch pedal is stiffer but no where near as stiff as I thought it was going to be. I've tried other uprated clutches out before and mine 10 times lighter in the pedal then the others.
I have only one thing I don't like about it though and that's the bite point. It's rediculously small and as has been said before, it's either off or on, on mine anyway. I have got used to it now but it's still a bit of an ****.
s3_trev
Northern Ireland
Ah right. I always understood it was agreed that the DMF was more like the standard feel, wheras the SMF was more "harsh" if you wanna call it that. Certainly with the two being physically different this idea would make sense. But if you feel its more to do with the brand of the components then I stand corrected lol!
s3_trev
Northern Ireland
Yeah I have found my bite to be really on or off as well, and im running a DMF. So it would seem that both have the same disadvantages with the SMF being able to cope with more power, maybe its the clear winner here, apart from maybe being more expensive.
S3Alex
Rarely neutral
Gold Supporter
I think it has at least as much to do with the components as the type of flywheel etc.
I keep grinding on about the Spec clutch,but this is an SMF setup,with the same feel as stock,t ability to slip the clutch in traffic etc,which paddle clutches are useless at,and will handle more torque than the gearbox can,so it's not so much the type of clutch setup,as the type of clutch plate(i.e. paddle Vs full face) and the friction material as well.
