Best DA polisher kit for a starter
Kayobong Oct 27, 2018
  1. Kayobong
    Kayobong Active Member Team Monsoon TDi Audi A3
    281
    170
    43
    So I've got quite a few swirls and a couple of scratches on my car and thought it's about time to pick up a DA polisher and since my birthday is coming up I thought I'd treat myself. I'd like a kit that comes with pads and compounds so I'm all set to go right off the bat. Looking for something under £150 which is able to do things like bumper and lights if possible, I've found this kit (https://www.cleanyourcar.co.uk/das-6-v2-dual-action-polisher-menzerna-intro-kit-1) and it looks to be alright but I'm not sure if its any good or not, any help or suggestions are appreciated.
    Cheers.
  2. Avatar
    Google AdSense Advertisement
  3. Neil Woodburn
    Neil Woodburn An Old Jock
    126
    33
    Adam14 and Kayobong like this.
  4. Kayobong
    281
    170
    43
    Thanks for the help! I'll definitely be adding this to my shortlist.
  5. jassyo06
    jassyo06 Grumpy Detailer ! Gold Supporter Audi S3 Black Edition Porsche Voodoo Blue S3 Saloon
    16,498
    33,890
    Kayobong likes this.
  6. Kayobong
    281
    170
    43
    jassyo06 likes this.
  7. jassyo06
    16,498
    33,890
    Dont add it to a list mate just buy it, because for £195 you wont get any better and it'll last and last the Das6 pro plus with a 15mm throw is the best/cheapest dual action polisher you can buy.....cheaper/inferior ones wont give the same results,the polisher in the link above only has a 9mm throw,so it will take far more time to get anywhere near the same results with a machine with a 15mm throw...the longer the throw the quicker/more aggressive the machine will cut/polish the paint....and time really does matter when you have a machine polisher in your mitts
  8. Adam14
    Adam14 Well-Known Member Team Ara Blue Audi S3 DSG
    586
    413
    Any tips / videos you'd recommend for a complete novice Jassy? Wanna give it a go but don't wanna mess things up on my first attempt.
    Sent from my SM-G965F using Tapatalk
  9. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator MQB Platform
    9,418
    12,943
    Kayobong and Adam14 like this.
  10. Adam14
    586
    413
    jassyo06 and Bristle Hound like this.
  11. jassyo06
    16,498
    33,890
    The DAS 6 Pro plus was in a comparison test with the Flex XFE 7 - 15 150 and the Rupes Mk11 lhr 15es it produced the same results as the Flex and Rupes which are more than twice the price of the DAS 6 Pro plus, a machine with a 15 mm throw will correct more surface area faster than a machine with a smaller throw mate videos
  12. Avatar
  13. jassyo06
    16,498
    33,890
  14. jassyo06
    16,498
    33,890
  15. jassyo06
    16,498
    33,890
    Nothing to do with money mate or being elites, it's to do with using the machines themselves, l have purchased/used 5 different machines this year, l have used the DAS 6 Pro it's not the best nor the worst but its a very old design and it's not as easy to use as the pro plus version nor will it deliver the same results as the pro plus but for a extra £50 or 3 bottles of quick detailing sprays, it's a must have £50 is well worth it, the only reason l sold my Das 6 Pro plus was because of the resonance/noise from it hurt my ears as I am prone to ear infections otherwise l would still have it the Flex machine polishers are quieter
  16. pxr5
    pxr5 Active Member Team Mythos TDi A7 Owner Group Black Edition quattro S-line owners group
    149
    147
    43
    There is always forced drive DAs too, like the Vertool. You don't have to worry about the spin stopping with over pressure. I used a standard DA for a while and it would stop with the minimum amount of pressure (hence the black line method). Now I use a force drive. Best of both worlds from rotary/DA.
  17. jassyo06
    16,498
    33,890
    If you stalled a dual action polisher it was because either through improper use or it was a cheap one with low torque the forced rotation polishers are not for beginners
    T-800 likes this.
  18. Bristle Hound
    9,418
    12,943
    @jassyo06 - Was only pulling yours and other chains buddy
    Don't say you've gone all sensitive on me while I've been away ... lol
  19. jassyo06
    16,498
    33,890
    Sensitivity..... not in my personality so the Mrs says lol hindsight l probably have over spent on polishers but hey I've always been called impulsive says the Mrs lol
    Bristle Hound likes this.
  20. Taxboy
    Taxboy Active Member
    109
    65
    Jassy I'm in the same postion as the OP in considering a polisher. I have read that the Pro Plus may not be the best for a beginner as you can't fit smaller size backing plates so would need another polisher for these areas.
    Could you offer any guidance of what sort of areas you couldn't use the Pro Plus for or is what I've read not totally correct
    Sent from my SM-T800 using Tapatalk
    jassyo06 and Kayobong like this.
  21. jassyo06
    16,498
    33,890
    The DAS 6 Pro plus is the best budget polisher on the market it can access most parts of the car door mirrors even you'll polish 80 % of a car properly and quicker than with a das 6 Pro, ideally you should team the DAS 6 Pro plus with a small 3 inch dual action polisher later on to complete the ideal combo
    Kayobong and Taxboy like this.
  22. Neil Woodburn
    126
    33
    Try a watch of this guy's you tube channel ( John ) for DAS Pro Plus - or search Forensic Detailing Channel
    Adam14 likes this.
  23. Kayobong
    281
    170
    43
    A4A4 and jassyo06 like this.
