unless of course you wanted to run 215 or 205 tyres on them to give you massive amounts of stretch, remove the arch liners, dial in a bit of camber, and possibly raise the rear to actually make the car function properly when you use it to carry things/people then it'll work.
fortunately, with that thing being on air you've got the chance of raising it when you need it, bit of a pain when your static.
it can be done, but if you wanna run low then you'll have to make sacrifices.
Theres photos in my thread showing et45 8.5J which gives you a good enough picture of what it looks like, bearing in mind the CH's will stick out a further 10mm, mine runs low(ish) and it had been rubbing on the top of the front arch, and on the arch liner and inside of the rear bumper.
the way i see it you'd have huge problems with et35 on a practical daily.
