  2. Dismiss Notice
Battery dying.2000 A3 1.9tdii
Colin Sutton May 20, 2020 at 1:16 PM
  1. Colin Sutton
    Colin Sutton Member
    35
    Not used car for 3 days [due to Wales lockdown] Engine turns over sluggishly then battery dies . Recently substituted battery for same reason as same was happening . Besides new battery , any suggestions please .
  2. Avatar
    snack-media
    Advertisement
  3. MPH
    MPH Active Member Audi A3 Manual
    307
    92
    Have you checked the alternator is charging the battery
    Sent from my SM-G930F using Tapatalk
  4. Dohcwp
    Dohcwp Setting the Standard Team Silver Audi A3
    275
    134
    43
    could be a bad ground, even though the car is parked certain systems like the alarm is still on and a bad ground has that effect, disconnect the negative terminal and put it back on, if there is a big spark then something is drawing too much power
  5. MPH
    307
    92
    Any luck with the battery situation yet Colin
  6. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    1,219
    345
    Do you have anything like a dash cam wired that's is constantly live or a dongle in ur obd port. Something like that might drain your battery.
  7. MPH
    307
    92
    My dash Cam is hardwired and never seems to drain the battery though
  8. hydro s3
    1,219
    345
    When I got mine fitted it always had a live feed going to it instead of turning of and on when the ignition was turned on or of and would drain the battery every few days unless started.
  9. MPH
    307
    92
    I think the issue could be DashCam dependent depending on what cam you have installed and how much it drains over period of time mine is Nextbase 312 g some models obviously drain more than others I would say.
    hydro s3 likes this.
  10. Colin Sutton
    Colin Sutton Member
    35
    No accessories ,no dash cam .
  11. MPH
    307
    92
    Then possibly a short seems to be the other alternative any codes Colin?
  12. Avatar
    snack-media
    Advertisement
  13. Dohcwp
    275
    134
    43
    do you have an aftermarket radio installed ?
  14. Colin Sutton
    Colin Sutton Member
    35
  15. Colin Sutton
    Colin Sutton Member
    35
  16. Colin Sutton
    Colin Sutton Member
    35
    This OK .
  17. MPH
    307
    92
    Have you cleared all the codes yet before you scanned
  18. MPH
    307
    92
  19. Colin Sutton
    Colin Sutton Member
    35
    All codes cleared. Rescanned & all clear. Thanks.
    hydro s3 and MPH like this.
  20. MPH
    307
    92
    Should any reoccur in the future please see my previous links
  21. Colin Sutton
    Colin Sutton Member
    35
    Bought a digital clamp meter to try to find a parasitical drain .
  22. Colin Sutton
    Colin Sutton Member
    35
    DCM.
  23. Colin Sutton
    Colin Sutton Member
    35
    Did a 12 mile trip down A48M / M4 to clear engine & charge battery . ( On my own no contact ). Parked up 6pm 13.14v. 10am today 12.5v ,so .64v loss in 14hrs . Will try clamp meter today.
