Bang & Olufsen retrofit question
Fraysa Aug 10, 2018
  1. Fraysa
    Fraysa New Member
    13
    Hi everyone.
    I own a 2013 1.4TFSI A3 and I'd like to upgrade it's sound system because the stock one is too low in quality for me.
    I currently don't have enough money to invest in a complete B&O speaker package so I'd like to start slowly investing in it.
    Can I start by purchasing a center speaker or subwoofer & amp? Will it work with my current speakers or do I need the whole set?
    Any advice would be awesome.
    Thank you!
  2. Avatar
    Google AdSense Advertisement
  3. RJ-8V
    RJ-8V Active Member Team Daytona Audi A3 S-line owners group
    577
    148
    43
    You can replace the center and tweeters. The sub won't work 100% with the build in amplifier.
    A3 8V Facelift Limousine
  4. Fraysa
    Fraysa New Member
    13
    Thank you for the quick reply. After looking at the definite retrofit thread I noticed he mentioned the MOST bus connector. Is this what you're referring to?
  5. RJ-8V
    577
    148
    43
    No the current power supply is your main unit. You can compare it with a "pioneer 4x50watt" radio. It can't deliver the needed power for B&O bas/mid/subwoofer speakers.
    That's why B&O has an external amp under one of the seats. The speaker wiring goes from the amp to the speakers and some input cables ( canbus, most etc) from the main unit to the amp.
  6. Fraysa
    Fraysa New Member
    13
    Oh, sorry, I misread your post. You're saying the sub won't work with the current amp. Yes, that makes sense. I figured I'd need to buy the amp if I'm going for the sub.
    Alright, I guess I'll start by replacing the center & tweeters. Thank you!
    EDIT: How to verify if the following will fit?
  7. A1DEYB
    A1DEYB Well-Known Member
    1,777
    96
    I’ve got it in my saloon, it’s decent but not all that and in my opinion it wouldn’t be worth the hassle. There was a thread on here somewhere about someone who upgraded to B&O and reading about it it did seem a real pain in the **** to do.
  8. -Ju-
    -Ju- Well-Known Member Team Floret Silver VCDS Map User SQ5 owners group
    2,975
    895
    I think the B&O is great but you do need to get the settings right and it will depend on the source input.
    As for retrofitting, it's a brave one to take on as afaik it will involve a complete rewire, which brings with it it's own issues and then there is the coding which may not be possible via vcds and require a specialist with dealer level equipment.
    Good luck!
  9. RJ-8V
    577
    148
    43
    Its a day work. Strip the interieur and door panels, new wiring, amplifier, connection to main unit in glovebox, all speakers, coding is max 10min work.
    Just code the main unit, parameters for the amp and main unit with VCP and done.
    DeeGee68 likes this.
  10. Adam14
    Adam14 Well-Known Member Team Ara Blue Audi S3 DSG
    579
    410
    In terms of quality once tweaked the sound is absolutely top notch.
    Sent from my SM-G965F using Tapatalk
  11. DeeGee68
    DeeGee68 DeeGee68 Team Mythos TFSI Owners Group Audi S3 Manual
    99
    33
    Have you done a B&O conversion? I am interested in getting it done.
    Regards.
    David
  12. Avatar
  13. Sparks43
    Sparks43 3rd Gear
    332
    96
  14. RJ-8V
    577
    148
    43
    No not done yet. Maybe in the future, but i need new door panels for the retrofit. Thats holding me back.
