SQ5 Back in Audi with SQ5
Devilz
Active Member
Birmingham, England
As per topic title, after 2 years I am back in Audi with SQ5.
Bought it on Thursday from Bristol. First car with 350+ bhp and undrewriter refused to insure the vehicle. :welcoming:
Very pleased with the power delivery, you put the foot down and you are touching 100mph in a flash. Had to keep eye on speedometer as I was keep on going over legal limit without realizing.
First thing first, did full scan when I reached home to see any fault codes and there were none except tpms warnings. Also I tried to activate mirror dip but for some reason can't make it work. Now I know knob needs to be on left to make it work but still it isn't working. Any advise?
Private plate is going on later today. Also filled the tyres with nitrogen all around. We all know remap is a must for this engine but there are too many companies claiming similar power gains, not sure which one to pick. APR, MRC, GIAC, REVO but that's down the line in near future.
Pics to follow soon
Code:
Thursday,09,September,2021,19:06:45:22532
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 21.9.0.1 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210824 DS330.0
www.Ross-Tech.com
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 74 81
          A5 A9 BB BC D6 D7
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CWGD)       Labels:. 06M-907-309-V1.clb
   Part No SW: 80A 907 559 B    HW: 06M 907 309 D
   Component: 3.0l V6 TFSI  H21 0003
   Revision: B2H21000    CVN: BF3DDAB7
   Coding: 2A2A00322526050B34080000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS01180A907559B 001003
   ROD: EV_ECM30TFS01180A907559B.rod
   VCID: 2E0508DFC092C53B05E-807A
   VINID: 9D196AAAA5A90D80800C910204A1E6720C
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
   Part No SW: 80A 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H05 1002
   Revision: --H05---    CVN: 997F11D9
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 698FBBC339FC620310C-803C
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 80A 907 379 E    HW: 80A 907 379
   Component: ESP9 Plus     H07 0657
   CVN: C561A5BE
   Coding: 1CAA14BE30A50A9F91A25893087E5292E6A59238280C50891A104A4967A549
   ASAM Dataset: EV_ESP9BOSCHAU426K 011013
   ROD: EV_ESP9BOSCHAU426K.rod
   VCID: 313F13A3D1ACDAC318C-8064
4 Faults Found:
420352 - TPMS Warning; Front Left Tire
          C1054 00 [032] - Pressure too Low
          Intermittent - Not Confirmed - Tested Since Memory Clear
420096 - TPMS Warning; Rear Left Tire
          C1058 00 [032] - Pressure too Low
417024 - TPMS Warning; Rear Right Tire
          C105A 00 [032] - Pressure too Low
415488 - TPMS Warning; Front Left Tire
          C1055 00 [032] - Flat
Address 08: Auto HVAC (E87)       Labels:* None
   Part No SW: 80A 820 043 G    HW: 80A 820 043 G
   Component: Klima Zone 3  H32 0090
   Coding: 6608000D5544440D02000100080000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiBHTCAU491 001013
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 211FE3E3814C6A4388C-8074
   Fresh air blower control module (front):
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001356049
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: B069829880PAG0MUFU02
   Rear A/C control head:
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143E17900CD050D87149FAE80B9110B31080000000000000000200016810A450122025601
   ASAM Dataset: EV_BCM1BOSCHAU736 018006
   ROD: EV_BCM1BOSCHAU736_018_AU49.rod
   VCID: 025D8C6F248A915BB16-8056
   Wiper motor control module:
   Subsystem 1 - Part No SW: 80C 955 119     HW: 80C 955 119
   Component: 426 RL 170303  040 0570
   Serial number: 00000001702272100615
   Coding: 5FC7F7
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Component: G397_RLFSS  H06 0002
   Serial number: 20293161X81A955555A0
   Coding: 02006E
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 15 05 2017  71350465
   Automatic dimming interior mirror:
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Component: Y7_Innenspieg  H09 0002
   Serial number: GX1CE112041723611502
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 G    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00009365
   Coding: 0D0104
   Control head for driving and comfort functions:
   Subsystem 6 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000093996004
   Coding: 000000
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM018KX1
   Coding: AACCF0C00C800000585400FFF08C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 3E25389F10F235BB95E-806A
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 000 403 17
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000A40D48F1R
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 000 403 17
   Component: SideSensor_Pf  001 0887
   Serial number: 3580000000035309E12A
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 032 702 17
   Component: SideSensor_Dr  002 0149
   Serial number: 351000C20D285DB0BE4I
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 030 704 17
   Component: SideSensor_Pr  002 0149
   Serial number: 352000C2028AB2B08BDE
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 030 403 17
   Component: FrontSensor_D  002 0149
   Serial number: 355000C20EA89EA0AAA-
   Coding: 2D2D2D
   Crash sensor for front airbag: front passenger side:
   Subsystem 6 - Part No SW: -----------    HW: 480 030 403 17
   Component: FrontSensor_P  002 0149
   Serial number: 356000C20EA89550E96M
   Coding: 2D2D2D
   Center pedestrian protection crash sensor:
   Subsystem 7 - Part No SW: -----------    HW: 480 030 804 17
   Component: PedP_Sensor_C  002 0149
   Serial number: 230000C207E22C107E3
   Coding: 2D2D2D
   Driver's side crash data pedestrian protection 2:
   Subsystem 8 - Part No SW: -----------    HW: 480 000 302 17
   Component: PedPSensor_D2  001 0887
   Serial number: I0M000000007B659EE9T
   Coding: 2D2D2D
   Passenger's side crash data pedestrian protection 2:
   Subsystem 9 - Part No SW: -----------    HW: 480 000 302 17
   Component: PedPSensor_P2  001 0887
   Serial number: I0N00000000F9639EE9Y
   Coding: 2D2D2D
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 020 802 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C12465B54B2BV
1 Fault Found:
9496851 - Front Crash Sensor for Pedestrian Protection
          B10E9 13 [008] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 80305 km
                    Date: 2021.04.14
                    Time: 15:27:34
Address 16: Steering wheel (J527)       Labels: 4M0-907-129.clb
   Part No SW: 80A 907 129 AC    HW: 80A 907 129 AC
   Component: Lenks.Modul   H02 0003
   ASAM Dataset: EV_SMLSKLOAU736 007012
   ROD: EV_SMLSKLOAU736_007_AU49.rod
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
   Component: FBenRDW       H17 0313
   Coding: 24AD96D4388006000123E9601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 42DD4C6F640A515BF16-8016
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 8W5 907 468 D    HW: 8W5 907 468 C
   Component: Gateway       H30 0308
   Revision: 5A010004    Serial number: 0485A291417228
   Coding: 0301000100008640540700000059003268920007000000000175078E10000000
   GVL: 01503C1008000200408C08000000C80001080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4ACD644F5C3A891B396-801E
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0002
   Serial number: 20170413105019 00087
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Component: J367-BDMHella  H10 9070
   Serial number: 5678485100
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 B    HW: 80A 907 397 B
   Component: LCM_MLBevo    H06 0017
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LCMLeftCONTIAU426 001009
   ROD: EV_LCMLeftCONTIAU426_VW41.rod
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000040071001
   Coding: 8800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323D1CAFD4AAE1DB616-8066
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 42: Door Elect, Driver (J386)       Labels:* None
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1QDG00B28
   Coding: 001F8A014001040000001082
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
   ROD: EV_DCU2DriveSideMAXHKLO_AU49.rod
   VCID: 08499E4702B6BB0BEF2-805C
Address 44: Steering Assist (J500)       Labels:* None
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000644712
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34311AB72EBEEFEB73A-8060
Address 46: Central Conv. (J393)       Labels:* None
   Part No SW: 8W0 907 064 CM    HW: 8W0 907 064 M
   Component: BCM2 MLBevo   018 0344
   Coding: 013500002F9100406301A0000600980233000010004306502F00000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 094F9B4319BCC203F0C-805C
   Anti-theft alarm system sensor:
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1701638F5
   Alarm horn:
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000068784594
Address 52: Door Elect, Pass. (J387)       Labels:* None
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1QDK0065N
   Coding: 001F8A014001040000001000
   Shop #: WSC 00732 210 00000
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
   ROD: EV_DCU2PasseSideMAXHKLO_AU49.rod
   VCID: 074B9D7B0FA8B473E68-8052
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035     HW: 8W5 035 035
   Component: MU-P-LND-EU   033 0917
   Serial number: A829E0H9273320
   Coding: 01245601FF0A000053111101000A00102F001AE701700100DE
   ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 74B1DAB76E3EAFEBB3A-8020
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Serial number: --------------------
   Multimedia System 1:
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL011QX
   Multimedia system control head:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 20031700000000000458
   Compact disc data bank:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1015
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0710
   ASAM Dataset: EV_DeckLidCONTIAU736 001014
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 48C95E4742367B0B2F2-801C
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 80A 907 777 N    HW: 80A 907 777 D
   Component: Fahrwerk-SG   H35 1214
   Serial number: 1003170283
   Coding: 1850182278
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 3C21329706EE27ABBBA-8068
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 80C 713 041 K    HW: 80C 713 041 K
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170403000787
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2615F0FFE8628D7BFDE-8072
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217     HW: 80A 907 217
   Component: BVS           H14 0042
   Coding: 0404020600000404024023A0AD0000FE00F0C020C020
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 6393A9EBDBD03853DA0-8036
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 170218202466
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 6889BEC722F65B0B0F2-803C
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1QDJ000EI
   Coding: 000F88000001040000001080
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 0A4DA44F1CBAC91BF96-805E
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS001 0737
   Serial number: CLSM1QDJ000GV
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
   ROD: EV_DCU2RearPasseMAXHKLO_AU49.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 176BCD3B5F0824F3768-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0008
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 01:48, VBatt start/end: 12.2V/12.2V)-----------
Reactions: 45bvtc, Sandra and paul wev
Pics to follow soon
Code:
www.Ross-Tech.com
A5 A9 BB BC D6 D7
Coding: 100000
CVN: C561A5BE
4 Faults Found:
Coding: 5FC7F7
Coding: 02006E
Light switch:
Coding: 230000
Coding: 0D0104
Coding: 000000
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 80305 km
Date: 2021.04.14
Time: 15:27:34
Alarm horn:
Data carrier:
Coding: 0710
Coding: 1850182278
I did chuckle at the underwriter refused to insure, especially when you state “you are touching 100mph in a flash”
Reactions: cosmicblue
Re the mirror dip function, do you folding mirrors?
Which year and trim is it - They are standard on the latest version but think they were an option on the previous model
Yep definitely an option rather than standard. Retrofit project perhaps.
Attached brochure details the basic spec and various options that were available which might be of interest to you.
saw the pic of the car in your separate thread - looks stunning :sign yum:
  • 0-Audi-Q5-and-SQ5-Price-list-Interactive-Edition-5-24022017.pdf
Thanks for sharing configuration.
What option do now I have to make it work. Also the high beam assist, is there anyway to keep it active all the time. I have to push the stalk forward to activate it every time I start the engine.
  • Sad
Reactions: 45bvtc
only option woukd be to retro fit - you’ll need to two new mirrors, a new switch and poss door controllors. once installed it will need to be coded. If you do a quick search there are kits available- not cheap though or you could try to source second hand or ask one of the members here.
re HBA on all my cars I’ve always had to push the stick forward to activate it -no doubt if it can be coded to come on automatically someone on here will know how to do it
Guess I have to live with manually dipping the mirror for now to avoid kerbs
Sent from my SM-F916B using Tapatalk
Reactions: 45bvtc
Few pics
Winter detail done over the weekend. Need to take car somewhere for better pics though
Looks very nice and those pictures are making me envious - I only have another 5 and a bit months to wait
Reactions: Devilz
I am thinking about wrapping door mirrors black as silver isn't to my liking. How much should I expect to pay or how hard is it to do myself?
Sent from my M2102K1C using Tapatalk
I am looking to change paddle shifters on my SQ5 as original ones are too tiny and I do not like the huge extenders available on bay. I have attached pics of my old C7 A6 steering wheel for reference, does anyone know the part number for those thick shifters as they look and feel way better IMO.
Gathering info for stage 1 remap down the line.
MRC - Not offering tune for SQ5 engine at the moment.
GIAC -N/A
APR - Quoting 110hp and 120nm increase
REVO - 70hp increase
CM Tuning - Apparently same guy who worked at MRC for couple of years quoted 50hp and 100 nm increase
RacingLine OEM+ - 60hp & 150nm increase
Which tune are other fellow owners running, need input. Thanks
I’ll be a bit optimistic on the APR quote but I could be wrong…I’m picking mine up in Newcastle on Monday morning,where u based in the uk mate?
Hi mate,where did you get the black front grill & vents?your car looks stunning
Reactions: Devilz
I am thinking to install Ghost II. Does anyone know which insurance companies recognise this as legitimate immobiliser as most don't. Especially the forum sponsors one.
Cete module seems very popular mod with air suspension. Anyone installed it on their cars?I can't find any UK dealer though who sells it or can install it.
You have to buy the Cete kit direct from the company in Germany.
No, it was optional - and quite an expensive option too - it was rare.
I think if you have the air suspension option there will be buttons in the boot space, left side, just below parcel shelf.
Apologies not quite with you here:
"It will still work as it should with the app."
What should work and which App are we talking about here?
This is the module I am talking about
Some low life scrapped the rear bumper while car was parked and broke the light. :rage::rage::rage:
