Firstly ,please pardon my lack of knowledge on these points.
Firstly with the key less push start........with my manual A3 with the stop start engaged when i come to a stand still it switches off (but ignition is still on ) and i turn off the key to shut down the car.
What do i do with the key less system with the stop start active when it cuts to the ignition mode and i want to simply switch off the ignition.?
On the auto box,when also in stop start mode when the car comes to a halt and the engine cuts out,do i need to put the box in neutral then apply the park gear?
Also when not in stop start mode,when the car comes to a halt, still in drive gear with my foot on the brake pedal must i put it in neutral then park ,or can you go from drive and simply press park ?
Again sorry for my ignorance here,its just than a standard auto box means you go through" neutral" on the way to "park".
