  2. Dismiss Notice
B8 S4 - Water Temp problems
nervus Dec 12, 2019
  1. nervus
    nervus Registered User
    1,459
    167
    Hi, Just got a 2009 s4 and had the Pulley and Belts changed and a mild map to 450hp. within a week, i've seen the water temperature rise above half way last night and only got it down by ramping the heating on max.
    The fans run constantly, and the coolant level is brim full in the bottle when it was in the normal zone before.
    I'm guessing its the Water pump. Can anyone confirm if this runs off the same belt? Any insight, similar experiences greatly appreciated!
    N
  2. Avatar
    snack-media
    Advertisement
  3. NHN
    32,017
    2,414
    Check the pipes to see if it's circulating, if not then either an air pocket or pump issue.
  4. nervus
    1,459
    167
    Thanks for the quick reply NHN
  5. Russboy
    Russboy Registered User
    529
    252
    Or coincidental timing and the thermostat has gone, fans on etc is what happened on mine.
    nervus likes this.
  6. Ginge247
    Ginge247 Registered User
    344
    138
    43
    Water pump runs off the auxiliary belt which is behind the supercharger belt on the crank pulley. Could just be an airlock I'm the system if it wasn't bled properly
    Sent from my JSN-L21 using Tapatalk
    nervus likes this.
  7. PenttisHSR
    PenttisHSR Registered User
    186
    74
    Sounds like the Thermostat, very common, classic symptoms.
    You need to get it replaced as soon as possible if so.
    nervus likes this.
  8. Mike B
    Mike B Registered User
    1,360
    64
    I thought all stats fail open to avoid sudden overheating?If the fan is on the sensor in the rad is showing the stat is allowing some circulation.Perhaps the pump is failing
  9. PenttisHSR
    186
    74
    B5 (S4) Thermostats fail open.
    B8 (S4) Thermostats fail closed unfortunately.
    nervus likes this.
  10. nervus
    1,459
    167
    Thanks guys, Its being looked at today!
  11. PenttisHSR
    186
    74
    Good Luck - Hope it's just a belt problem
  12. Avatar
    snack-media
    Advertisement
  13. nervus
    1,459
    167
    Sorted thanks for the input.
    Swapped both the Water pump (metal) and the Thermostat which has resolved the problem. No point not swapping both while the front of the car was off!
    jdp1962 likes this.
  14. rum4mo
    rum4mo Registered User
    2,222
    578
    When last did your belts get changed, I'm dragging my heals a bit on this job, both belts are in the boot, but it is a bit cold out there, car is a 2011 and mileage is only 25K miles only used on high days and holidays, as its easier to park and wash wife's car!
  15. nervus
    1,459
    167
    The belts were changed prior to the problems as a new smaller Forge S/C Pulley kit. It looks like it was the Thermostat as the water pump was the metal type and in good order. However, the S/C has to come off to get access to both parts so for most of the invoice being labour it made sense to swap both at the same time.
    Whole job cost £350 from a local trusted garage.
