B8 lowering problem
Alaistair
Northern Ireland
Hi all,
I have a 2010 A4 S Line 2.0 tdi 170
Can somebody help with a suspension problem I have, before lowering the car was sitting slightly lower on the drivers side. I just thought this was down to weak springs, today I have fitted a set of Eibach Pro's 35f 30r. It has dropped 18mm at the front and 5mm at the rear but is still sitting higher on the left and more at the rear. Has anybody any ideas on this, I'm thinking something to do with the suspension links. However I did set suspension or ride height on the lower arm linkage on the rear.
Subframe alignment could cause it
Reactions: Alaistair
I know the car is much heavier on the right because of fuel tank location.
When setting my bag psi's, i need an additional 15psi on the rear right to equalise the height at the back. sounds the same tbh
