Hi Guys,
My 2011 model 2.0 TDI Avant is going crazy, sometimes it will not start, and the errors that come up on the dash are as follows; Stability program fault, Parking brake fault, headlight range control defective.
The car either starts first thing or it wont and then the errors come up on the dash, if the car starts it drives 100% normal, no limp mode, nothing strange, also no errors appear when driving, they only come on start up. When the 3 errors come up on the dash screen the engine cooling fan also turns on and goes nuts, it will only turn off if I remove the key from the car and close/open it again. Sometimes it will even continue to blow a bit and I need open/close it a second time or put the key back into the car to stop the fan blowing.
I went to see a fiend of mine to see it with vagcom, and this is the result, we're lost as we can't figure it out, we tried looking for the ECU relay, which is mentioned online for other models as 109, but we couldn't find it anywhere. Does anyone know where it might be?
Any help is highly appreciated.
Sunday,13,March,2016,16:48:30:63648
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: WAUZZZ8K3BA****** License Plate: *******
Mileage: 66020km-41022mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
VIN: WAUZZZ8K3BA064437 Mileage: 66020km-41022miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
Component: R4 2,0L EDC H29 9096
Revision: 25H29---
Coding: 12194012232403080000
Shop #: WSC 00150 219 87778
ASAM Dataset: EV_ECM20TDI03L906022NN A02011
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7EF3D950E10FD5CE0C-802A
3 Faults Found:
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 06335 000 00000
VCID: 7EF3D950E90FD5CE0C-802A
2 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 5
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:33:10
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x002E
Hex Value: 0x0295
Hex Value: 0x00FF
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 7
Reset counter: 5
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:33:52
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0027
Hex Value: 0xB995
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 032200
VCID: 000FA7A893FBA33E7E-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0071
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
Component: KLIMA 1 ZONE H08 0180
Revision: A1000000 Serial number: 01111020101298
Coding: 34200000
VCID: 77FDCC74C635E4864F-8022
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:31
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000819782
Coding: 260050914034AF010001000300001D0D0F1C07080601010100 0000
VCID: 3C771358BF9307DE62-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 071010 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:43:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50901028501120
Coding: 100203
VCID: 489F7F88FB4B5B7EF6-801C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Freeze Frame:
Temperature: 21.0°C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0L76AA
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 44876BB8CF637F1E1A-8010
Crash sensor for side airbag; driver side:
Serial number: 6334MSME580561356
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME58042E6CP
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME17714626B
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME407442245
Crash sensor for front airbag; driver side:
Serial number: 63732SME48743930.
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME7B743A3CE
No fault code found.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372JJ800002
Coding: 000017
VCID: 3D711E5CA4890ED655-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 N HW: 8K0 920 930 N
Component: KOMBIINSTR. H25 0258
Revision: 00000000 Serial number: EJC32WEAA
Coding: 0F04100002000008000000
VCID: 387F0F488BAB2BFE86-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G109238004
Coding: 00CF07
VCID: 0109A2AC98F1AA3671-8054
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.70 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 53
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:39
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.90 V
Count: 7
Bin. Bits: 10000
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000011456115
Coding: 011C02204100410001
VCID: 4A9B4580E547A96EE0-801E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0135966900
Coding: 0100062020B904408120023680000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:35
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000011458736
VCID: 49997A8CE041A276E9-801C
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000759455
Shop #: WSC 00000 000 00000
VCID: 34673B7897C3CF9EAA-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Freeze Frame:
Voltage: 11.80 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 39790A4C70A132F679-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:32
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H07 0350
Revision: 00000011 Serial number: AUZ5Z6J1475895
Coding: 0500048004020500015B070000
VCID: 44876BB8C7637F1E1A-8010
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000109201912
Coding: 010C02204000210001
VCID: 458176BCCC5946160D-8010
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000109202023
End-------------------------(Elapsed Time: 02:29)--------------------------
www.Ross-Tech.com
Revision: 25H29---
3 Faults Found:
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
Coding: 160504
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 5
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:33:10
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x002E
Hex Value: 0x0295
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 5
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:33:52
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0027
Hex Value: 0xB995
Hex Value: 0x00FF
Revision: 00002001
Coding: 032200
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Coding: 34200000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:31
Coding: 00FD11
Coding: 025028
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:43:00
Coding: 100203
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Freeze Frame:
Temperature: 21.0°C
Coding: 000017
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Coding: 00CF07
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.70 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Freeze Frame:
Fault Priority: 1
Fault Frequency: 53
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:39
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.90 V
Count: 7
Bin. Bits: 10000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:35
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Freeze Frame:
Voltage: 11.80 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000004
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:32
Component: Display
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
