As the title says, is this a difficult job? Had a quick search on here but couldn't see what I was looking for. Any help is gratefully received!
Sounds easy, but is popping the glass out as easy as it sounds? I'll try a search, again!Pop the glass out, unscrew the mirror cap, unscrew indicator
Thanks ruairi83, I'm thinking about getting the dynamic indicators but nervous about breaking the glass.......or anything else!Did it on brother car yesterday.
Take 10mins per side and. Two screens and it’s all about piloping out.
I have spare wing mirror indicators
Genuine if you need
As always be gentle but firm and it will pop off...Thanks ruairi83, I'm thinking about getting the dynamic indicators but nervous about breaking the glass.......or anything else!
This guy makes it look much harder than it is. Once you get the initial crunches out the way that will make you butt go like a bunnies nose don't do what he did and try and prise it away from the other sides instead get you fingers/hand in the gap and ease it off from the middle in the same directing you started in, don't twist it.
Then undo lots of screws you can see then man handle the cover off, the clips are pretty strong.
shows the screws better in this one.
SIMPELS
the spare that you mention - are they dynamic or the standard ones?Did it on brother car yesterday.
Genuine if you need
Standard ones matethe spare that you mention - are they dynamic or the standard ones?
Genuine if you need
Sorry for late reply. Yes I still have these mate and yes they are the same part.I’m in need of just the drivers side to replace a faulty one on my ‘14 A4 3.0 TDI Black edition (I think they’re same part?) if you still have them available?
