keirGERS
Hello all,
basically, I bought my first German car last week after having Japanese after Japanese. Went to veiw it, no fault code, no engine management illuminated and it ran fine. The car in question is a 2006 Audi A4 TFSi Quattro S-Line Auto.
Over the last week little niggly things have started to annoy me, I'll make a list, probably easier that way.
Engine management bulb illuminated ( P0171 & Cylinder 3 Misfire (forgot to get the code before I cleared it))
Slowly started to idle a lot worse, I've read on here people saying they are a noisy engine, but it's very noisy, has a very bad diesel clatter sound, according to the girlfriend *like a tractor*. I thought along the lines of the cam chain tension, but I'd of thought that would of been more of a rattle.
When the car is first started when cold, it misfires badly at idle. Standing around the rear you can hear the 'dunf, dunf, dunf' as it try's to idle out the exhaust. Usually clears after 10-15 seconds, however now it has started to return when the car is warm.
Feeling a slight stutter occasionally (like it's running out of fuel) under partial throttle, however, fine at WOT.
Engine management occasionally flashes a repeatedly a few times then goes off under WOT.
Loosing coolant (don't know if it could be related).
Idles very poorly, rocks the whole car.
At first I thought the misfire could be coilpack related, so phoned my local audi dealership to find it hadn't had the coilpack recall. So that got done yesterday, however I still have all of the above issues.
Bought a OBD2 Bluetooth connector and downloaded the app. I've found I'm boosting at a steady 8-9PSI. I've read on another topic it should be around 10-10.5PSI. Don't know how good the OBD2 connector will be though so I'm not 100%.
Read that the carbon build up apparently gets better as the engine warms up (mine appears to get worse) so that eliminates that I suppose.
It also feels sluggish, considering it's 200bhp, but I don't know if that's just because my old car was a Type R and the one before that a 320bhp S14a. Obviously the Audi is a big heavy car, but there isn't much or a turbo kick, you can barely feel it, which makes me think it's under-boosting.
Any recommendations would be greatly appreciated, as at the moment I feel like I'm going to be shooting in the dark.
Keir
Keir
