  2. Dismiss Notice
B6 A4 window driving me nuts
Yogibear84 Oct 30, 2018
  1. Yogibear84
    Yogibear84 New Member
    Hi all,
    Got an issue with my A4 B6.
    Driver's (O/S) window (only) doesn't work. I can operate all other windows with the driver's switch. Replaced the switch, motor and electrical control module which is attached to the motor. Wiring all looks to be fine. Still nothing, no power getting to motor. What the hell else could it be? Only odd thing i noticed is when i pulled the old switch apart there was a very slight blackening of the contacts on the switch for the window in question. not completely blown by any means.
    If you can solve my problem I'll send you a free window motor! Looking forward for some answers!
  2. Avatar
    snack-media
    Advertisement
  3. SemedoB6
    SemedoB6 Black and white a4
    506
    142
    43
    Might be window regulator.
    Pretty common issue. And if it really is the problem I would advise OEM.
    I bought cheap ones from ebay and they lasted exactly a year.
    Do you hear any noise when operating the switch?
    Sent from my SM-N960F using Tapatalk
  4. Yogibear84
    Yeah, don’t think it’s the regular. Motor isn’t engaging at all.
  5. SemedoB6
    506
    142
    43
    Are the wires intact? I mean. You have no broken wires where it connects to the body of the car?
    If motor isn't even engaging might be a broken wire somewhere.
  6. Yogibear84
    Nope, wires look mint. No idea!
  7. SemedoB6
    506
    142
    43
    Sorry for the silly question..
    But is it really plugged in? Have you done any work recently that required unplugging it and forgot to plug it back on?
  8. goodwoodgreens3
    goodwoodgreens3 Member
    67
    Check the wiring inside the rubber boot where the hinges are when you open the door. Seems quite a common problem!
  9. BigCat
    BigCat Member
    82
    As goodwood says, check wiring inside rubber boot at door hinge. Thats what happened mine....:thumbs up:
    cormach21 likes this.
  10. Yogibear84
    Sorry for the late response but I've all but given up! not the wiring in the rubber boot either. :wtf:
