B120F 11 [137] - Short to Ground
Kim Lerhaugen
Hi.
Got this code.
9572113 - Ignitor for Passenger Airbag Release Valve
Had the same in september but just cleaned the conector on the airbag behind the glowebox passenger side and I could clear the code.
Try the same a few days ago but it will not go away. Somebody have any idea what to do?
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00HYS2X
Coding: 3032343631334E303437554A304C34473053
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 36352330A8C8FBDB99E-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40632FL64D0T6
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB40612FL649P1+
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB40592LSO4AP3Y
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB400852JMSG28E
Crash sensor for front airbag: driver side:
Serial number: 3554VRB401852JMS4H9X
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400G52K1O5181
1 Fault Found:
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 144726 km
Date: 2021.01.18
Time: 00:09:44
NHN
Site Sponsor
Check if theres one on the drivers side, if its tye same part number, swap & see if fault stays that side, which is wiring or moves to other side, which would be component fault.
