Hi Guys,
Just wondering what your opinions are on swapping tyres front to rear?
I've covered 7000 miles now and my fronts are between 4-4.5mm tread and the rears are around 5mm.
My front tyres are really tatty, they have lots of stone cuts in the tread and the leading edge of the tread blocks is breaking away. This is because when Audi test drove the car on two occasions for steering noises, it has burned off half a tank of fuel just manoeuvring round the car park. Basically the tyres are knackered but legal. Question is, do I swap the good rears to the front to even out wear and preserve the fronts a little longer?
I have tried my best to get Audi to pay for at least two tyres and failed, not happy about that and will get onto it tomorrow. As far as I see it, they have worn down the tyres as a consequence of diagnosing the car and I don't see why I should foot that bill. I tread depth gauged the tyres before it went in last time, they lost 0.5mm of tread when in for 2 weeks on the front, gained cuts in the tread blocks and the leading edge breaking away.
I've also got strange wear on one of the front tyres (I know Conti's wear terrible as normal though). My pressures are done every week or two, set to 38 front and 35 rear as per the recommendation on the door. Let me know what you make of these depths on the front for even wear. The measurements from left to right below, are the inside of the corresponding tyre to the outside. The car has been four wheel aligned three times by Audi in the last 2500 miles because of suspension work, so that isn't out of spec!
N/S Front Tyre:
4mm 4mm 4mm 4mm (All Good).
O/S Front Tyre:
4.5mm 4mm 3.5mm 4mm (Very Strange!).
Below are some pictures of the tyre wear, the pictures aren't me trying to find bad parts of the tyre it is just something I noticed when putting tyre gel on and took them in situ... there are many more little cuts in them. Obviously the rear won't wear as much as the front and there is more load on the front, but I have never seen tyres scrubbed in like this (3rd Pic down shows the scrubbing I mean) and with tread falling away.
Good Rear Tyre with nice wear....
Bad front tyre....
Thanks in advance,
Matt.
N/S Front Tyre:
O/S Front Tyre:
Bad front tyre....
Thanks in advance,
Matt.
