Avf pd130 stock smic
Audi-paddy Sep 21, 2018
  1. Audi-paddy
    Audi-paddy New Member
    21
    Just wondering what the max bhp is on the stock intercooler and pipework is
  2. Avatar
    Google AdSense Advertisement
  3. Wahlstrom
    Wahlstrom Active Member
    553
    180
    43
    Around 200bhp..
    Higher, and more boost is required, along with other stuff.. Then the plastic sides becomes the culprit.
    Either get a full aluminium smic or a fmic to lower the intake temp.
  4. Wahlstrom
    553
    180
    43
    I need to know if some oem ic can be fitted to the A4 B6...
    Found a A6 fmic oem that has a large thin area instead of a small bulky one.
    Need to look oem for MOT
  5. DieselJake
    DieselJake Well-Known Member VCDS Map User
    3,522
    993
    I'd recommend aftermarket due to metal end tanks and less plastic bits to go wrong, no personal experience but I believe any factory one may need a bit of adaption anyway.
    Shouldn't need to look OEM for an MOT but if you don't want it to stand out best thing to do is use black joins and spray stuff black.
    Wahlstrom likes this.
  6. Wahlstrom
    553
    180
    43
    That metal pipe that goes from turbo side to IC, can it be removed or is it a part of the front?
  7. Wahlstrom
    553
    180
    43
