Auto gearboxes
Jimmy TDI
Pro Tinkerer
Where there two different kinds of auto box fitted to these?
I've noticed when looking for a manual that some of the later auto models come with gear change buttons on the steering wheel. Are these fitted with a better revised box, or were the change buttons just an optional extra?
I really want a manual due to the fact the auto boxes pretty much always fail, but if the later ones have a revised, stronger box, I might just be tempted by one.
Cheers Jim
mrnice
As far as I'm aware-
Tiptronic- Money pit
Multitronic- bankruptcy
I thought some v6/v8 models wear fitted with trad torque converter transmissions tho?, which would maybe be more reliable
I really wanted an auto myself but talked myself out of it and stuck with manual due to tales of misery and doom..
Tooand
I've owned a 2000 A4 2.8q with a tiptropic for 3yrs and it drives like a dream, quick with silky smooth gear changes. I recently bought a 2003 A6 2.5q diesel with the same box and it also drives spot on
Jimmy TDI
Pro Tinkerer
How can you tell which box it has without physically looking for the part number on it?
I've never owned an auto before, and would prefer a manual if I'm totally honest, but they're few and far between in good condition, and there are plenty of well specked auto's popping up all the time.
Alan Gunn
The manual selector on the tiptronic is in the middle of the selector and on the cvt it's at the bottom by "D".
CVT selector goes P.R.N.D tiptronic is P.R.N.D.3.2.1(i think).
DGSdale
That only applies to earlier tiptronic boxes (and I don't know exactly when the change was). My '98 2.8 quattro had the 3,2,1 with the tip. selector slot in the middle (opposite D) as you say but my current 2003 3.0 quattro has the 3,2,1 replaced with S (sport) with the tip. selector slot toward the bottom opposite D.
If the car is a quattro auto, then the 'box is definitely an old fashioned, Torque Converter type with the addition of the tiptronic feature: quattros never got the CVT (Multitronic - or fondly known as 'Multichronic').
Jimmy TDI
Pro Tinkerer
So are the auto boxes on these a bit more reliable than the ones the B6 A4 got then, or do they fail just as much?
ms1083
Please read some of my recent posts. My poor allroad is currently sat with its 3rd dead tiptronic gearbox - 2 boxes were Audi remanufactured ones both died with unrelated problems in a period of 4 years so yes they do fail (just out of warranty!!!) and are horrifically expensive to buy £3000ish and to fit 10-11 hours labour. If you find a manual one buy it quick they are rare. 2004 car with buttons on steering wheel to change gear. BAU code gearbox. Gearbox code in front of service book.
Jimmy TDI
Pro Tinkerer
Yeah I'm going to stick to manual as I intended.
There was just a really nice, well specked, and maintained auto come up for sale a mile away from my house at a reasonable price that had turned my head.
Arrkon
Back in a "B"
Staff member
Moderator
Regional Rep
FWD = Multitronic
Quattro = Tiptronic
Rich81
Sorry for the thread hijack.... What gearbox would my 2001 s6 have then?
It will be the Tiptronic. ZF HP24A gearbox. They are pretty reliable I did a lot of research on these generally only commom failure is torque converter. If you scan the auto box ecu and see
17125/P0741/001857 - Torque Converter Clutch: Stuck OFF / No Power being transferred
It's the torque converter failure (car will still drive ok.
Hairless wonder
Hi thanks for reply, I can't get 1st or 2nd gear... Even in manual mode.
PLUGGED IN SNAP-ON DIAGNOSTIC MACHINE
TC - P0730 - Gear Ratio Monitoring: Incorrect Gear Ratio
Any ideas?
Rich81
I heard that these boxes go into limp mode which locks them in 3rd gear, perhaps this could be why can't get 1st and 2nd due to the fault code. I suppose this could be due to a sensor but the ross tech site doesn't mention electrical issues
http://wiki.ross-tech.com/wiki/index.php/17114/P0730/001840
Perhaps someone who knows these boxes inside out can say how the car monitors the status as the question I'm asking myself is how does the car know there's a gear ratio problem? I'm guessing it asks for a shift out of 3rd and doesn't see it on something like the distance sensor f125 and therefore throws a fault code. It that's guessing. Could do with the VAG self study guide on these boxes...
Bratcop
Consensus seems to be try an oil change first and if that doesn't fix it it time for a new box.
I just rebuilt mine. Was an 5hp24a. There are two typical failures. First a drum breaks, making it impossible to hold pressure on a drum. Secondly, a small seal fails again making it impossible to maintain pressure. If it works ok when its stone cold (for only like 3 minutes) then defaults to limp, I bet it's the seal. Pull bottom pan and check for pieces, there should be some of a drum broke from pressure spike.
Good luck
Sent from my LG-US996 using Tapatalk
Rich81
Hi Bratcop,
Hugely impressive that you rebuilt your box yourself. Just getting the box out the car is a bigger job than most would even consider.
Lots of stories that these are originally built in 'surgically clean' environments at the factory etc, clearly you've proven it's possible to do it in a 'normal' garage environment.
Hopefully get many miles of driving out of it!
I have the same car in same colour. 167k miles and still going strong.
Bratcop
Clean for sure, but cmon is not a hard drive lol. I just use clean fluid, clean tools and clean bench space. Btw, for the record, I got it out and in alone and without a hoist (it wasn't fun however )
Bratcop
